90 CRX HF vs DX
Old Apr 4, 2006 | 11:22 AM
SupraRXZ's Avatar
Default 90 CRX HF vs DX
Besides MPFI vs DPFI
what are the differences between the two?
Old Apr 4, 2006 | 11:29 AM
CRX Toad's Avatar
Default Re: 90 CRX HF vs DX (SupraRXZ)
Gearing, weight, seats, rear wiper, rear cargo area, AC, tilt, HP, 16V vs 8V, front bumper support, impact areas, spindles, brakes, axles and I'm sure there are more.
Old Apr 4, 2006 | 11:30 AM
drdisco69's Avatar
Default Re: 90 CRX HF vs DX (CRX Toad)
The DX doesn't have an HF badge on the back.
Old Apr 4, 2006 | 11:39 AM
jlicrx's Avatar
HF has smaller gas tank
HF is about 150lbs lighter than DX
BTW - my 88 HF has factory A/C
Old Apr 4, 2006 | 11:42 AM
Smokinsax's Avatar
The Boot
Default Re: 90 CRX HF vs DX (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">The DX doesn't have an HF badge on the back.</TD></TR></TABLE>
Old Apr 4, 2006 | 12:10 PM
31flavorscivic's Avatar
Default Re: 90 CRX HF vs DX (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">
BTW - my 88 HF has factory A/C</TD></TR></TABLE>
right on
Old Apr 4, 2006 | 12:58 PM
SupraRXZ's Avatar
so if i was to swap a d16z6 motor in a HF it would be better and easier? does the HF have rear disc brakes? or is that just SI's
I got a complete d16z6 engine that i want to put in with 92 civic axles, this engine and axles and everything is coming off of my ef9 DX that got in a accident from the back so the engine is fine and i got a HF CRX now and i was wondering would it be a easy swap?
Old Apr 4, 2006 | 01:04 PM
SiMateoAko's Avatar
Default Re: (SupraRXZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupraRXZ &raquo;</TD></TR><TR><TD CLASS="quote">so if i was to swap a d16z6 motor in a HF it would be better and easier? does the HF have rear disc brakes? or is that just SI's</TD></TR></TABLE>
Dont know how it would be easier, but a z6 will definately give you more power than the b7.
Only 90-91 SI had rear disc.
The front brakes on the HF are really small. I'd look into upgrading them as well if you're going to put in a power house like a z6.
Old Apr 4, 2006 | 01:06 PM
SupraRXZ's Avatar
Default Re: (SiMateoAko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiMateoAko &raquo;</TD></TR><TR><TD CLASS="quote">
The front brakes on the HF are really small. I'd look into upgrading them as well if you're going to put in a power house like a z6.</TD></TR></TABLE>
should i take the DX brakes and put them on the HF?
cause i practicly have a ef9 DX with a z6 motor and i can take all the parts from that, like i got a SI guage cluster, si seats, and wat stuff from the DX should i get to put on the HF besides the Z6 motor i got
Old Apr 4, 2006 | 01:10 PM
crxnj's Avatar
Yeah swapping into the HF is easier obviously because it already has mpfi...
Take the D16z6,DX 5spd tranny,dx brakes,hubs,axles and put it on your car..Dont get me wrong you can use the hf brakes,hubs,axles with the new engine,,But the Dx brakes are larger and the axles are stronger....And if you ever want to swapp b-series or whatever you dont need to change the hubs again..
Old Apr 4, 2006 | 01:20 PM
SupraRXZ's Avatar
Default Re: (Mr.speaker)
sorta a noob at all this but what is a hub?
and all i need to do the d16z6 swap is take the jumper harness, and then change the injector clips and use a distributor adapter from rywire?
and the ride is realy nice and smooth cause i got kyb shocks, are those swapable too?
Old Apr 4, 2006 | 01:23 PM
CRX Toad's Avatar
The hub is what the wheel attaches too. Also the rear disc brakes really don't do anything for you. I would just upgrade to DX/Si hubs/spindles or a set of 90-91 Civic Ex spindles a good set of pads and Brembo blanks. Don't waste your time on slotted or cross drilled rotors.
That would be a good swap for a HF.
Old Apr 4, 2006 | 01:26 PM
crxnj's Avatar
Yeah you can change the shocks..And if you going with rywire you get their obd1 conversion harness,distributor adapter,,,Then get a heated 4 wire o2 (if the motor didnt come wit it)..And of course an obd1 ecu..
Old Apr 4, 2006 | 01:41 PM
SupraRXZ's Avatar
what about getting DA front brakes and hubs?
90JPRCRX
22
Jan 3, 2020 10:50 PM
Mechman456
Nov 11, 2006 11:11 AM
GSRSNATCH
Apr 16, 2003 07:38 PM
NightHawkC5
Feb 22, 2003 07:05 AM
bluebullet
10
Jun 16, 2002 06:58 PM
