how much power will a d15 put out hooked up to an mpfi
Old Apr 4, 2006 | 11:13 AM
classciv's Avatar
Default how much power will a d15 put out hooked up to an mpfi
just looking for a decent engine to put in my 91 crx si. found one with 86k on it out of a 90 dx. so it is the 1.5L. will hooking up the mpfi intake and droping it in my 91 si give it any more power or will it still be the wapping 68 horses that comes stock in the dx. any info would be great. thanks guys
Old Apr 4, 2006 | 11:28 AM
Targa250R's Avatar
be professional
Default Re: how much power will a d15 put out hooked up to an mpfi (classciv)
Stock '90 D15B2 is 92hp. Stock '91 D16A6 is 108hp. An MPFI D15 would be somewhere in between.
Old Apr 4, 2006 | 12:36 PM
classciv's Avatar
Default Re: how much power will a d15 put out hooked up to an mpfi (Targa250R)
sounds ok to me, i just want to be able to make it up hills without dropping it down to 2nd gear
Old Apr 4, 2006 | 12:41 PM
jlicrx's Avatar
stock D15B1 from Civic STD is only 70hp
Old Apr 4, 2006 | 01:07 PM
classciv's Avatar
Default Re: how much power will a d15 put out hooked up to an mpfi (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">stock D15B1 from Civic STD is only 70hp</TD></TR></TABLE>
yeah that is the one i was originaly talking about. so d15 b1 has 70 hp, and the d15b2 has 92hp?
Old Apr 4, 2006 | 02:12 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by classciv &raquo;</TD></TR><TR><TD CLASS="quote">yeah that is the one i was originaly talking about. so d15 b1 has 70 hp, and the d15b2 has 92hp?</TD></TR></TABLE> Yup, I believe if the B1 has a 16-Valve head the lower power is a result of the computer and restrictions in the intake tract. A D15B1/2 with MPFI will be almost equivalent to a D15B7 in terms of power.
Old Apr 4, 2006 | 04:00 PM
djphonics's Avatar
Default Re: how much power will a d15 put out hooked up to an mpfi (dr_latino999)
Do a Vtec d15 or a ZC. I think you'll be much happier.
Old Apr 4, 2006 | 04:44 PM
Default Re: how much power will a d15 put out hooked up to an mpfi (djphonics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djphonics &raquo;</TD></TR><TR><TD CLASS="quote">Do a Vtec d15 or a ZC. I think you'll be much happier.</TD></TR></TABLE> Why change when you can fiddle with what you have?
Old Apr 4, 2006 | 06:40 PM
weppskilla's Avatar
Quote, originally posted by djphonics »
More Power!!!!
Old Apr 4, 2006 | 08:45 PM
classciv's Avatar
Default Re: how much power will a d15 put out hooked up to an mpfi (weppskilla)
hahaha yeah i am not looking for a racer out of this one, i have my other crx for that, this one i just need to be reliable, so i need opinions i have a chance to buy a d15b2 with tranny and 86k original miles for $350 is it worth it or should i keep looking for a cheaper d15 or d16 i dont really need the tranny, but he will not seporate and i guess i coule always use another good 5 speed dseries tranny sitting around, what do you guys think?
Old Apr 4, 2006 | 09:11 PM
1point7db2's Avatar
Do the mpfi swap, it will help alot, but a crx si cam or sohc non vtec zc cam is the icing on the cake. A shorter geared Si tranny will help to.
Old Apr 5, 2006 | 04:15 AM
classciv's Avatar
Default Re: how much power will a d15 put out hooked up to an mpfi (blownEG93)
yeah iwill always have the si cam from the d16 that i pull out maybe after i put a few miles on her with the d15b2 i can do an over haul on it and swap the si cams in
Old Apr 5, 2006 | 05:04 AM
ludesrv's Avatar
Si cam, Si intake manifold, 92-95 Si exhaust manifold (stock) and you will free up a good ammount of power, enough for you to not downshift, and all the parts are relatively cheap! Having a short geared Si tranny will help out too.
Old Apr 5, 2006 | 06:16 AM
classciv's Avatar
Default Re: (ludesrv)
yeah i will have everything with the exception of the 92-95 exhaust manifold, i never knew they where different, are the larger? or what is the difference?
Old Apr 5, 2006 | 06:20 AM
harmonator84's Avatar
Default Re: (classciv)
i was wondering the same thing about the headers...i hear ppl say that all the time????
Old Apr 5, 2006 | 06:27 AM
classciv's Avatar
Default Re: (harmonator84)
i also heard somthing one time about people putting a b20 intake manifold on the 92-95 dseries engines but i never really looked into it
Old Apr 5, 2006 | 06:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by classciv &raquo;</TD></TR><TR><TD CLASS="quote">i also heard somthing one time about people putting a b20 intake manifold on the 92-95 dseries engines but i never really looked into it</TD></TR></TABLE> Have you seen the B20 intake manifolds lately? One it wont clear the hood and two it wont bolt on.
Old Apr 5, 2006 | 07:02 AM
classciv's Avatar
Default Re: (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Have you seen the B20 intake manifolds lately? One it wont clear the hood and two it wont bolt on.</TD></TR></TABLE>
just said i heard something about it, hoods can be modified and the b20 has been around for a long time so it could have been an intake manifold off of the older b20
Old Apr 5, 2006 | 07:08 AM
janz3n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by classciv &raquo;</TD></TR><TR><TD CLASS="quote">yeah i will have everything with the exception of the 92-95 exhaust manifold, i never knew they where different, are the larger? or what is the difference?</TD></TR></TABLE>
think those exhaust manifolds are factory headers. 4-2-1 or just 4-1 i dont know .. i also could be wrong.. i know b18s had the factory headers.
anyone can correct me if im wrong cuz i know i am.
Old Apr 5, 2006 | 08:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by classciv &raquo;</TD></TR><TR><TD CLASS="quote">just said i heard something about it, hoods can be modified and the b20 has been around for a long time so it could have been an intake manifold off of the older b20</TD></TR></TABLE>Again, have you ever seen a B20 intake manifold? It would stick so far out of the hood you would need a very very impressive cowl. This is why everyone running a B20 in anything NOT a CRV uses the B18B intake. Also, do you also fail to realize we are talking about a D-Series motor so no B-Series intakes will fit.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">92-95 Si exhaust manifold (stock) </TD></TR></TABLE> I thought that the exhaust manifolds didn't come 4-2-1 until the D16Y8.
Old Apr 5, 2006 | 08:52 AM
si0385.'s Avatar
i believe you are refering to just the throttle body replacement
and all d-series stock exhaust manifolds are 4-2-1
Old Apr 5, 2006 | 09:12 AM
crooked muffler's Avatar
Default Re: (si0385.)
no 88-91 Im very sure is 4-1, I just removed mine recently and put the well priced megan header on
my setup:
d15b2, mpfi swap, si cam, si trans.
pulls pretty good especialy in comparison to dpfi!
the d16z6 IM flows much better tho and I may upgrade to that...
Old Apr 5, 2006 | 10:07 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. &raquo;</TD></TR><TR><TD CLASS="quote">and all d-series stock exhaust manifolds are 4-2-1</TD></TR></TABLE>Nope, off the top of my head I know that the D15Bxx series all was 4-1
Old Apr 5, 2006 | 10:13 AM
UltimX's Avatar
Default Re: (cheap4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheap4dr &raquo;</TD></TR><TR><TD CLASS="quote">no 88-91 Im very sure is 4-1, I just removed mine recently and put the well priced megan header on
my setup:
the d16z6 IM flows much better tho and I may upgrade to that...</TD></TR></TABLE>
Which battery is that?
Also. the z6 had a 4-2-1 header(which is what i have now), a6 and dx/hf (crx) had 4-1. the y8 had a 4-2-1 also.
Old Apr 5, 2006 | 12:15 PM
Default Re: (UltimX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">Which battery is that?</TD></TR></TABLE> Odyssey PC 680
Modified by dr_latino999 at 4:48 PM 4/5/2006
