Civic 91 Brake Problem
Old Apr 4, 2006 | 10:48 AM
Shaminda's Avatar
Default Civic 91 Brake Problem
Hi,
Hope you can help me.
Last week one of my rare brakes started to bind when backing the car. It was similar to suddenly applying emergency brake while backing up, but to a single wheel. The problem was intermittent.
I opened the drum and found the brake cylinder was leaking (oil was spilled on the brake pads) so I replaced with a new one. (only the cylinder, not the pads)
But still the problem persists. I reduced the brake by turning the adjustment screw. The wheel turns freely in the forward direction. But it is so tight in the reverse direction. All the wheel bearings are fine and no abnormal sounds.
Thanks in advance.
Old Apr 4, 2006 | 12:20 PM
Shaminda's Avatar
Default Re: Civic 91 Brake Problem (Shaminda)
Please Guys, Don't let me down. I need your help
LXcivic2000
Mar 27, 2017 07:41 AM
mikeds122
Sep 25, 2004 12:55 PM
blklude
Jun 27, 2003 06:30 AM
