finally figured out my ecu and i need help
I mentioned before in other topics that i couldnt figure out how to read my codes. well i figured it out. there is a red push buttin wired to my ecu and i had to ground out the one wire. I grounded it out and when i started the car the ecu light was on, well i pushed the button then it blinked twice and then a really fast short blink. I have a 88-91 book but i have the p28 ecu and thats not the stock ecu. Can anyone hook me up with some trouble shoot codes? THANKS
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StraightCivic »</TD></TR><TR><TD CLASS="quote">it blinked 2 times slow then 1 fast does that mean both oxygen sensors are out?
and would that prevent my car from starting?</TD></TR></TABLE>21 VTEC spool solenoid valve
Each slow = 10
Each Fast = 1
Each slow = 10
Each Fast = 1
now would that prevent my car from starting and where can i get one? does that mean my motor is fucked? i dont know anything about vtec motor its my first one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StraightCivic »</TD></TR><TR><TD CLASS="quote">now would that prevent my car from starting and where can i get one? does that mean my motor is fucked? i dont know anything about vtec motor its my first one. </TD></TR></TABLE> No that wouldn't prevent your car from starting. Your motor is fine, it is just not getting a proper read from the VTEC circuit so a wire could be loose, the solinoid could be bad, etc etc.
JeDiMaster
10
Oct 15, 2010 06:00 PM
