whats the Order to repin a si distrbutor plug to fit a zc distributor
whats the Order to repin a si distrbutor plug to fit a zc distributor.
the si has 7 wires and the zc only has 5 wires
match up all the couls together... there should be two solid white wires.. so if your car doesnt start then switch them. then the two extra wires from the ecu go to the blue/green blue/yellow wires. and again what swap did you just do and was your car dpfi before it or something?
h22_crx
Apr 4, 2006 10:24 AM
ScottEK
Sep 26, 2002 11:50 AM
