Is Rocket motorsport a good place to get cams?
Well i hear some good things about them, but i want to know if anyone has their cams and if they like them?
these cams will be put in my ITR so i want something that will give me power
I run the M22x's in my B16b and I LOVE them. If you have the motor to back them and are able to tune it, the M22's would be an awesome cam for you. They idle like stock, and they make power about as high as you want them to. I have a stock air box and exhaust manifold on my motor and they made power clear upto 8,700
, a super strong top end charge. And the valvetrain, IMO, is the best that money can buy....I've never once heard of RM valvetrain dropping a valve or binding, and people have thrown the largest of cams at them to 10k...never once a problem. Big big
from me
from me
expletive yea, ive never heard ANYTHING bad about Rocket cams. Once i start building my crvtec(hopefully soon
) my only cam choice is the m24x.
Modified by KINGSOL18 at 4:18 PM 4/4/2006
) my only cam choice is the m24x. Modified by KINGSOL18 at 4:18 PM 4/4/2006
I have a couple friends who've rocked the M double deuces and were more then pleased with them.
Rocket
Rocket
the only bad thing I know about them is that they are actually made/ground here locally at Crower. As far as power is there any threads with these cams on a actual cam shoot out against any reputable cams?
edited
Modified by GUILOTINE at 4:12 PM 4/4/2006
edited
There is a misunderstanding out there on what a billet is in camshaft terms these two descriptions are from webcams site. The only steel billets (Machined form steel bar stock)I know of is roller cams and the steel OBX P.O.S. Dan
BILLETS:
The blank shafts that the camshafts are made from.
CAST BILLET:
A term used to describe a camshaft which is made from a casting. The material for the casting is a special grade of iron alloy called "Proferal
BILLETS:
CAST BILLET:
The only "billet" cams I have heard of were OBX. Go for it. Factory Honda cams are classified as "cast steel" as they have a higher cromieum content than the chilled cast iron. Kent cams made me "billet" cams in the 90's the heat treat cost was big, but at the time no-one made Honda cams.Best I could do was a hard weld from Elgin or Mega-Cycle, same as Comtec. Chilled cast is want you want, unless you are running "roller" rockers. OK Bob. LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itralex »</TD></TR><TR><TD CLASS="quote">Rocket Cams are great
someday i hope i can get some dough and run the M24x's
btw, i am biased
**** man, I wanna see those in your motor BAD, and I am kinda biased as well.
...And yes it is true that the RM cams are made form Crower blanks, but I wouldn't consider that a bad thing...Crower has been in the buisness for yeeeears.
btw, i am biased
</TD></TR></TABLE>**** man, I wanna see those in your motor BAD, and I am kinda biased as well.
would the M22x work good in my JDM ITR with stock 11:1 cr? I have a ram air intake and a Rage header, and right now I am looking for a cam that needs the least bit of tuning but can deliver power on my stock compression. The pump gas in my country is horrible so a compression bump is out of the question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE »</TD></TR><TR><TD CLASS="quote">the only bad thing I know about them is that they are actually made/ground here locally at Crower. As far as power is there any threads with these cams on a actual cam shoot out against any reputable cams?
edited
Modified by GUILOTINE at 4:12 PM 4/4/2006</TD></TR></TABLE>
As far as I know, they are NOT ground by Crower but another company down in that area....
edited
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VenGeanceDrag »</TD></TR><TR><TD CLASS="quote">
As far as I know, they are NOT ground by Crower but another company down in that area....</TD></TR></TABLE>
yes they are, but as Clean Rice stated above the new Crowers really havn't had any issues to my knowledge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam »</TD></TR><TR><TD CLASS="quote">has anyone used the chip RM gives you custom for your car??? did it chip fully tune the motor ?</TD></TR></TABLE>
ill be using the chip on first start up. just waitin on my header and some plug wires.
i haven't hit vtec in a year! iim sooo close
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">The chip is either a Hondata basemap if you have Hondata, or a Crome basemap. Each is tailored for your engine.</TD></TR></TABLE>
so i can take this chip to the dyno and change things on it with crome ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teamdiesel »</TD></TR><TR><TD CLASS="quote">would the M22x work good in my JDM ITR with stock 11:1 cr? I have a ram air intake and a Rage header, and right now I am looking for a cam that needs the least bit of tuning but can deliver power on my stock compression. The pump gas in my country is horrible so a compression bump is out of the question.</TD></TR></TABLE>
Shoot Rocket an email on his website. From what I understand, I THINK 11:1 CR is the lowest those cams "like." He's a very helpful guy. I can't say ANYTHING bad about him.
And how would Crower be any different from Comp, Web, megasycle??? Most American cam companys use the same machines. Its all in the grinder. Crower and Rockets cams are all within .001 of each other on the base circles and have No run out what so ever. That to me shows that its a great cam.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_Rock77 »</TD></TR><TR><TD CLASS="quote">
Shoot Rocket an email on his website. From what I understand, I THINK 11:1 CR is the lowest those cams "like." He's a very helpful guy. I can't say ANYTHING bad about him.</TD></TR></TABLE>
Please contact a dealer if you have any questions.
