pr4 code 13 +
code 13 ? what can i do to get rid of this code?
code 14 being thrown... i had the iacv plugged into the wrong place but i am still getting code ...
plug colors for intake temp sensor? i have a plug with red/wht or yel and a grn/white or yel can't tell the color due to the small stripe and lighting ? are those the right colors... or similar i know its not right on but hoping someone can help
Code 13 on PR3s happens a lot because some of them have internal PA sensors and some of them have external ones. But that code shouldnt come up in an EF unless you had a bad or unpluged PA sensor.
The eacv has blu/yel and yel/blk wires, and the iat sensor has the ones you listed. It probably threw the code beacuse you mixed the wires around. Reset the ecu and see what happens.
edit: we have the same post count, haha
swapped out my ecu's and its all good now... no codes or atleast there wasn't for the 20 sec i pulled it outta the garage and parked it
