Help! heat doesnt Work
Old Apr 3, 2006 | 08:43 PM
FastHatch90's Avatar
Default Help! heat doesnt Work
If there is anyone that had the same problem or may know wut the solution is please let me know. Thanx
Old Apr 3, 2006 | 08:56 PM
firebane's Avatar
radiator, thermostat, water pump, heater core
Old Apr 3, 2006 | 09:16 PM
Default Re: (firebane)
wouldnt the car overheat if the raditor thermo or waterpump wasnt working properly? when my car warms up it only warms up to the middle of the 1/4 and half mark. So its not running at the Middle.....
Old Apr 3, 2006 | 09:27 PM
firebane's Avatar
Default Re: (FastHatch90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastHatch90 &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt the car overheat if the raditor thermo or waterpump wasnt working properly? when my car warms up it only warms up to the middle of the 1/4 and half mark. So its not running at the Middle.....</TD></TR></TABLE>
if its at the half mark or even 1/4 mark and blowing hot air, you are perfectly fine.
Old Apr 3, 2006 | 09:35 PM
payneth's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by firebane &raquo;</TD></TR><TR><TD CLASS="quote">
if its at the half mark or even 1/4 mark and blowing hot air, you are perfectly fine.</TD></TR></TABLE>
yeah thats the way mine is and it runs perfect.
different thermostats can cause your temp to run at a different temp too you know.
i had a spoon thermo in my old hatch and it ran at a hotter temp causing the needle to be at half way mark at all times. Making the engine a little hotter, causing my heat to be a little hotter as well.. I liked it.
But yeah check the normal things as stated above.
AaronJ
Sep 23, 2007 05:20 PM
lv6l
20
Aug 17, 2005 01:20 PM
integlspwr2k
May 28, 2005 02:54 AM
pr8elu8desi
Jun 21, 2004 06:18 PM
onyx00
Jul 20, 2003 09:04 AM
