resistor value for srs?
Old Apr 3, 2006 | 04:51 PM
timmy0tool's Avatar
Default resistor value for srs?
car is a 92 accord. for those with aftermarket steering wheels, what is the resistance value of the airbag to trick the srs system into thinking there is an airbag attached to the system? i've heard of 2.2 ohms. is this correct?
<FONT SIZE="3">and removing the srs bulb in the cluster is not an option!</FONT>
Old Apr 4, 2006 | 08:52 AM
91DA9's Avatar
Default Re: resistor value for srs? (timmy0tool)
I am not sure what it is, but here is a free bump and a warning I am sure you are well aware of. Do not check the resistance with a multimeter, as it might set the airbag off.
Old Apr 4, 2006 | 06:09 PM
rainforest's Avatar
Default Re: resistor value for srs? (91DA9)
2.2 ohms is correct.
Old Apr 11, 2006 | 08:28 AM
timmy0tool's Avatar
thanks rainforest!
dem0nk1d
32
Sep 29, 2011 02:58 PM
lsturbo00
Oct 5, 2009 04:22 PM
siRone
Dec 5, 2008 11:18 AM
Xgen
Jan 8, 2006 06:42 AM
cdfive.
Apr 25, 2005 05:57 PM
