light bulb problem
Old Apr 3, 2006 | 03:31 PM
y2kferari's Avatar
Default light bulb problem
i'm a big guy under the hood. but my 93 ex civic is a pain in the *** with changing the bulbs. i have silverstars i'm tryin 2 replace the stock bulbs with and the driver's side light is blocked from the back side with that power steering or whatever capsule. and I can't pull it out from the front, the bumpers in the way. how do u replace the lights, on the driver's side atleast, without braking something? thanx
Old Apr 3, 2006 | 06:13 PM
BlueIntegraBoy's Avatar
Default Re: light bulb problem (y2kferari)
Slide the power steering fluid reservoir up to remove it from the bracket, then you can replace your bulb.
Old Apr 3, 2006 | 06:23 PM
.Ry's Avatar
.Ry
Default Re: light bulb problem (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Slide the power steering fluid reservoir up to remove it from the bracket, then you can replace your bulb.</TD></TR></TABLE>Yup..should slide right out. If for whatever reason it wont come out, or you dont want to...just remove the bumper.
Old Apr 4, 2006 | 02:09 PM
y2kferari's Avatar
Default Re: light bulb problem (turner7205)
got it out thanx
Old Apr 4, 2006 | 02:10 PM
y2kferari's Avatar
got the light bulb out thanx. quick ? do u know where i can get some good racing rims from 4 my civic? 4/100
96_civic_gsr
Honda Civic (2001 - 2005)
Jun 2, 2010 10:35 AM
Lucman
Apr 10, 2008 02:35 PM
JDM.Sleeper
Aug 6, 2007 03:01 PM
iverson3yoo
Jul 29, 2005 04:42 PM
granracing
Apr 7, 2005 02:32 PM
