question what is better turbo or supercharger??????
what would u guys put in ur s2000 if u had the option of turbo or supercharger, i like turbo because of the blow off valve but i wanna know what u guys think any help will be good thank you..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellows2k »</TD></TR><TR><TD CLASS="quote">what would u guys put in ur s2000 if u had the option of turbo or supercharger, i like turbo because of the blow off valve but i wanna know what u guys think any help will be good thank you..</TD></TR></TABLE>
HAHAHAH he doesnt care about the HP ... he only loves it because of the BOV ....ROFL
Nishant (6:26 PM 4/3/2006): yo, find the pic of that piece you attach to your exhaust that makes the SC or Turbo sound and post it in that thread. i forgot the name of it
ROFL ....
yellows2k, if you like BOV sound just by this instead .. its cheaper
ADM Turbo Simulator
The Turbo Simulator will simulate the “psssst” noise generated from the blow off valve of a turbo-equipped vehicle.
The Turbo Simulator comes complete with all hardware, which includes a manual push button trigger mechanism as well as a vacuum switch trigger mechanism.
After setting a trigger boost level through an adjustable setscrew on the vacuum pressure switch, every time you reach the set boost level, the Turbo Simulator will simulate the “psssst” noise generated from the blow off valve of a turbo vehicle. This is activated by lifting off the throttle.
An additional override button also allows you to trigger the Turbo Simulator anytime.
FEATURES
Push/Pull On/Off switch
Rotational volume control
Override push button to trigger Turbo Simulator anytime
Vacuum pressure switch to trigger Turbo Simulator at a set boost level.
5” x 2 1/5” x 1 ½” ABS plastic brain housing
2 durable 12-volt high output speakers for maximum volume and clarity
EZ six wire installation guide
Priced at S$380 with installation.
http://www.autodesigns.com.sg/turbo-sound.htm
ROFL ....
ADM Turbo Simulator
FEATURES
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellows2k »</TD></TR><TR><TD CLASS="quote">i like turbo because of the blow off valve </TD></TR></TABLE>
ROFL...SC's have a BOV also, but the sound is more suppressed.
don't buy something because of the way it sounds unless its an exhaust tone. when it comes to your motor, you want what is best for your wallet.
i dont know about u but my plan for my s2k is turbo, its alot more aggresive and yah that BOV noise is crazy, i love that, but on the other hand if u daily drive ur s then ur propably gona get sick of that noise each time u let go of ur gas, or like change gears,loool
but ive heared that superchargers are more reliable. and run from the begging and dont have a that turbo lag, so u get the power all through all the rpm range, unlike the turbo it doesnt kick in like lets say at 4 to like 9
not actually the soung but also horsepower i heard that a turbo could produce about 360hp with a thicker head gasket from revhard so i was thinking of doing that what do u guys think is it true or bull ????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi »</TD></TR><TR><TD CLASS="quote">S/C in the S will not boost until 4500 on and wont hit full boost till redline.</TD></TR></TABLE>
havent you seen ff2skip's SC dyno numbers....he pulling 20psi on a SC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjektSlideways »</TD></TR><TR><TD CLASS="quote">The SC pulley is the size of a dime or what?</TD></TR></TABLE>
And issues with belts slipping/losing tension?
I personally prefer the tornado, best mod ever.
http://www.tornadoair.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellows2k »</TD></TR><TR><TD CLASS="quote">not actually the soung but also horsepower i heard that a turbo could produce about 360hp with a thicker head gasket from revhard so i was thinking of doing that what do u guys think is it true or bull ????</TD></TR></TABLE>
360HP? Please, InlinePro has a MUCH better kit nad has made over 550rwhp on a stock block with a headgasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fknfast »</TD></TR><TR><TD CLASS="quote">havent you seen ff2skip's SC dyno numbers....he pulling 20psi on a SC</TD></TR></TABLE>
I know skip, but you know what I meant. Hes probably boosting at idle. LOL
Turbo=uses free exhaust gases
(snuperfarker)=parasitic
Dont get me wrong, the wicked sound of a supercharged stang is jizztackular. But for an s2000 i would get the turbo rout. 3-9 k pulls= omg jizz
just my 2c
just my 2c
