wheel studs replace . need to take the hub out ?
Old Apr 3, 2006 | 02:13 PM
EK FLY's Avatar
Default wheel studs replace . need to take the hub out ?
hi
i was going fast and i hit a bump and 3 of my wheel studs broke .. lol now I 'am trying to replace them .. but I have one question do I need to remove the wheel hub to replace them .. I try to take em out but I couldnt do it bc there was no room in the back of the hub to pull them out
I did a little diagram so u guys know what I'am talking about
btw the car is a 90 integra ls front wheel studs
Old Apr 3, 2006 | 02:14 PM
SlamminS85's Avatar
Default Re: wheel studs replace . need to take the hub out ? (TURBO-WAWA)
musta been one hell of a bump, yeah remove the hub
Old Apr 3, 2006 | 02:27 PM
boost'd_crx's Avatar
take the spindle out of the hub replace studs repack the wheel bearing and put back in.
Old Apr 3, 2006 | 02:42 PM
reno96teg's Avatar
the hub will have to be pressed out. might as well put in a new wheel bearing while you're at it.
and something had to be wrong with your studs. i've seen wheels shattered into pieces and the studs were still left intact.
Old Apr 5, 2006 | 10:34 AM
EK FLY's Avatar
Default Re: (reno96teg)
yea it was dam bump i didnt see from far loll .... well anyways i gess i'll have to remove the hub .. one way or another
Old Apr 5, 2006 | 10:43 AM
gsr dood's Avatar
Default Re: (TURBO-WAWA)
probably werent on as tight as they should have been....happened to me once
kvastek
Honda Civic (2001 - 2005)
Jan 11, 2022 05:29 AM
cmfnelson
Nov 24, 2012 01:03 AM
fit2slo
Honda Fit
Oct 28, 2008 10:56 PM
Pompiuses
Sep 12, 2005 06:57 AM
InfamousRS
Feb 11, 2002 09:36 PM
