is it possible to run aftermarket cams on stock valves and springs?
Old Apr 3, 2006 | 01:52 PM
nylshatch's Avatar
Default is it possible to run aftermarket cams on stock valves and springs?
i got a type r head all brand new valves and valve springs in it just out the machine shop. i was wondering if i could run a aftermarket cam with the stock stuff? also i dont plan on reving it that high i know its a stupid question but i need to know
Old Apr 3, 2006 | 02:00 PM
GetawayInMoscow's Avatar
Default Re: is it possible to run aftermarket cams on stock valves and springs? (nylshatch)
Crower makes a cam you can run with ITR valvetrain. Also I think people say you can run stage 1 cams with stock valvetrain.
I would just run CTR cams though...
Old Apr 3, 2006 | 02:14 PM
Nick M's Avatar
Default Re: is it possible to run aftermarket cams on stock valves and springs? (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">Crower makes a cam you can run with ITR valvetrain. Also I think people say you can run stage 1 cams with stock valvetrain.
I would just run CTR cams though...</TD></TR></TABLE>
whose stage 1 cams?
why screw around, upgrade your valvetrain
Old Apr 3, 2006 | 02:19 PM
nylshatch's Avatar
Default Re: is it possible to run aftermarket cams on stock valves and springs? (Nick M)
i just got the head from a friend and its just out of the machine shop 0 miles on it thats why i was asking. also i got p72 pistons im building a ls/vtec wut kind of compression should i have with a ls block p72 pistons with a type r head?
Old Apr 3, 2006 | 02:21 PM
kingkong's Avatar
compression calculator!
http://www.c-speedracing.com/h...c.php
ONCE AGAIN
Old Apr 3, 2006 | 02:25 PM
nylshatch's Avatar
Default Re: is it possible to run aftermarket cams on stock valves and springs? (kingkong)
thanx forgot about that site
bigboy56
11
Sep 20, 2012 02:35 PM
eg4life1202
14
Jan 1, 2007 04:43 PM
geces23
Aug 8, 2006 05:00 PM
haggar
Jul 20, 2003 06:02 AM
