help! eg Si wont start
ive been putting this off for some time now and i really need to get it fixed. i have a 92 civic Si. 200,000 complety bone stock miles. anwhile back my car would start shutting off after about 15 mins of running under normal conditions. ive never beat on this car at all, babied its entire life. after about 15 mins of driving it shut off and not start back up.
i was thinking it was the main relay getting hot and messing up but i replaced it and the fuel pump, both of those are new. when i go to start it back up i can hear the pump priming like normal, but no start. any ideas
Do you allow time for the car to warm up? It kind of sounds like you have a problem when the car goes into open loop! (or closed dont remember) which also has to deal with the o2 sensor and the ect sensor! Have you also tried to see if you have spark to the spark plugs?
it does cranks over. forgot to minchen(cant spell) that it doesnt have spark and no pgmfi light
Modified by Performance Freaks EG at 2:15 PM 4/3/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealth_EK4 »</TD></TR><TR><TD CLASS="quote">coil or distributor maybe?</TD></TR></TABLE>
agree, that or check the mail relay. my friend had a hatch that did that and he just changed the relay and it worked just fine. good luck.
bart simpson
15
Apr 6, 2010 12:21 PM
yusoslo
Sep 28, 2003 12:29 PM
i think it usually about an hour more or less wait till it will start up again
