white smoke after ctach can install
Old Apr 3, 2006 | 11:04 AM
bigcheese42's Avatar
Default white smoke after ctach can install
So, I just installed a new block with a mugen head gasket. I put about 400 miles on it last week and parked it for the weekend. Today I put a diferent catch can system on and drive it until it warms up and it starts blowing a lot of white smoke out of the tail pipe. Would the rerouting of the catch can lines have anything to do with the smoke, or am I looking at a head gasket problem?
Old Apr 3, 2006 | 11:06 AM
Mugen Mike's Avatar
Default Re: white smoke after ctach can install (bigcheese42)
White smoke = coolant. Have you checked for coolant in your oil?
Old Apr 3, 2006 | 11:11 AM
Dave_B's Avatar
Do you smell a sweet smell?
Old Apr 3, 2006 | 11:13 AM
white rocket's Avatar
Default Re: (Dave_B)
Most likely coolant. Perhaps the Mugen HG didn't hold up or the bolts were torqued too much or not enough.
Old Apr 3, 2006 | 11:57 AM
No it is not a sweet smell like coolant, it smells like burning oil. Well I took out the new catch can and it was completly full. This is from 5 min. of under 3k rpm. So, I put the old can back on and routed the lines like I had them before. It is still smoking a little, but it had so much oil in the exhuast that it is leaking from the header donut. So I think everything is ok.
So now my question is this. I have the stock pcv system pluged. I am running a line to the 14mm allen plug to the left (driver's side) of the oil filter (bottom of the catch can). A line to the breather on the valve cover (middle of catch can) and a line with a pcv valve to the intake manifold (top of catch can). Any body see a problem with this setup. I know it is not the best way, but I'm working with what I got. Thanks for reading the long post.
Old Apr 3, 2006 | 02:43 PM
Circuit Star-29's Avatar
Default Re: (bigcheese42)
Im about to do the same setup as the Endyn guys... Check it out and see if it works for you...
Scroll down to near the bottom of the page to see the catch can setup...
http://www.theoldone.com/articles/badtothebone/
Old Apr 4, 2006 | 01:00 PM
Default Re: (Circuit Star-29)
I actually have endyn can and had it set up like that on my last motor. When I was installing the new block I totally messed up the pasenger side freeze plug and could not use that port for the tubing.
So, basically I have it like this pic http://www.theoldone.com/artic...g.jpg
except the lines running to the passenger side are going to the driver's side and the line going to the driver's side is going to the valve cover. So do you think I should just plug the other hole on the catch can or run it to the breather on the valvle cover?
Old Apr 4, 2006 | 01:43 PM
Haleiwa-Brando's Avatar
Was the head gasket put on the right way?
Old Apr 4, 2006 | 06:33 PM
Default Re: (Haleiwa-Brando)
I am pretty sure I put the gasket on the right way.
Old Apr 4, 2006 | 09:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigcheese42 &raquo;</TD></TR><TR><TD CLASS="quote">I am pretty sure I put the gasket on the right way.</TD></TR></TABLE>
Pretty sure? Sounds like theres a little internal conflict with being absolutely sure or not. Either it's a yes or a no!
Old Apr 4, 2006 | 10:04 PM
If you installed the gasket upside-down or backwards, you'd have oil everywhere...
You need to correctly install this thing...I.e., get another plug.
Dunno what else to say but good luck.
Redprelude98
Nov 25, 2008 10:42 AM
cars101
20
May 6, 2007 02:38 PM
gmboogy
Nov 29, 2006 01:44 AM
4dr*sleeper
15
Aug 1, 2005 02:08 PM
Layziebtnh055
10
Apr 16, 2004 02:22 PM
