B16 Valve adjusment tool isze???
Old Apr 3, 2006 | 10:51 AM
dkboyny11's Avatar
Default B16 Valve adjusment tool isze???
I have a B16A1 and I'm wondering if I need the 10mm or the 12mm valve adjustment tool for my motor. Thanks
Old Apr 3, 2006 | 12:52 PM
APEX CRX's Avatar
Default Re: B16 Valve adjusment tool isze??? (dkboyny11)
Believe it a 10mm
Old Apr 3, 2006 | 01:04 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: B16 Valve adjusment tool isze??? (APEX CRX)
10mm
Snap-on sells a tool that works well for this:
http://buy1.snapon.com/catalog...talog
Old Apr 3, 2006 | 04:16 PM
dkboyny11's Avatar
Default Re: B16 Valve adjusment tool isze??? (88DXCRX)
Thanks fellas, I've got to replace the head gasket on my car and thought there was a tool for the job.
This tool is out of stock at every place that sells it, what gives?
Old Apr 3, 2006 | 06:11 PM
88 rex's Avatar
I would just buy a gear wratchet set instead. The kits cheaper, you get more tools to use, and it can be used just like the snap on tool. I always use my gear wratchet and have great results. It's super easy.
Old Apr 3, 2006 | 06:16 PM
Blue Hybrid's Avatar
Default Re: B16 Valve adjusment tool isze??? (88 rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">I would just buy a gear wratchet set instead. The kits cheaper, you get more tools to use, and it can be used just like the snap on tool. I always use my gear wratchet and have great results. It's super easy.</TD></TR></TABLE>
do you mean gear wrench? like a combination wrench with a ratcheting head?
Old Apr 3, 2006 | 06:42 PM
88 rex's Avatar
Default Re: B16 Valve adjusment tool isze??? (gold EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold EF &raquo;</TD></TR><TR><TD CLASS="quote">
do you mean gear wrench? like a combination wrench with a ratcheting head?</TD></TR></TABLE>
Gear Ratchet set.
Old Apr 5, 2006 | 12:48 PM
dkboyny11's Avatar
That a good idea, you can put the screwdriver through the center with that wrench?
Old Apr 5, 2006 | 01:08 PM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkboyny11 &raquo;</TD></TR><TR><TD CLASS="quote">That a good idea, you can put the screwdriver through the center with that wrench? </TD></TR></TABLE>
Yup
Old Apr 9, 2006 | 04:42 PM
4gencivicef9's Avatar
how much do you want for the hasport b16 harness and when I get this I wont have to wire anything up right????
Old Apr 9, 2006 | 04:43 PM
Default Re: B16 Valve adjusment tool isze??? (4gencivicef9)
what are the specs on adjusting the valves
thedudefromjerz
Jan 22, 2009 08:18 PM
RACEPAK
11
Dec 11, 2005 03:03 PM
komat
Jun 16, 2005 04:01 AM
thehondaguru
Jun 15, 2003 10:28 AM
NXSpoon
Jun 8, 2002 10:16 AM
