reverse shut off?
Old Apr 3, 2006 | 10:28 AM
whiteef-8's Avatar
Default reverse shut off?
some times when i throw it into reverse the motor dies slowly, drops idle then just dies. wussup wit that?
it doesnt die all the time in reverse, just sometimes.
Old Apr 3, 2006 | 10:38 AM
crxnj's Avatar
Default Re: reverse shut off? (whiteef-8)
You have an HF crx with a swap?
Old Apr 3, 2006 | 12:22 PM
whiteef-8's Avatar
Default Re: reverse shut off? (Mr.speaker)
yea
Old Apr 3, 2006 | 01:02 PM
crxnj's Avatar
All the swapped hf crxs have that problem it seems..The reverse light is connected to the ecu,,and you have to pull pin b9 (green and black wire)..My old crx hf had this same problem as yours and when I pulled that wire the problem was gone..
Old Apr 3, 2006 | 01:04 PM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">All the swapped hf crxs have that problem it seems..The reverse light is connected to the ecu,,and you have to pull pin b9 (green and black wire)..My old crx hf had this same problem as yours and when I pulled that wire the problem was gone..</TD></TR></TABLE>
I never knew that, good info
Old Apr 3, 2006 | 03:45 PM
ICeDoUt's Avatar
I can back that up, de-pinning this also does not make you lose the function of your reverse lights either.
Old May 4, 2006 | 12:59 PM
whiteef-8's Avatar
Default Re: reverse shut off? (ICeDoUt)
couldnt i just cut the wire? instead of depinning?
Old May 5, 2006 | 02:21 PM
whiteef-8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteef-8 &raquo;</TD></TR><TR><TD CLASS="quote">couldnt i just cut the wire? instead of depinning?</TD></TR></TABLE>
Old May 7, 2006 | 08:12 AM
whiteef-8's Avatar
Old May 7, 2006 | 08:20 AM
RCautoworks's Avatar
Yep
Old May 7, 2006 | 11:17 PM
whiteef-8's Avatar
Default Re: reverse shut off? (90blackcrx)
well i just cut the wire, and everythangs great, but
occationally, I would turn on the motor, it would start but then dies in bout 4 secs.
then it wont start again till i wait acouple of minutes. what could this be?
Old May 7, 2006 | 11:30 PM
JJ's civic's Avatar
main relay?!?
Old May 8, 2006 | 05:12 AM
Phshorty's Avatar
Default Re: reverse shut off? (joeny12985)
id say pull the main relay and open it up see if there are any dry soder joints. if so then re soder, or buy a new one. on ebay its about 40 bucks used, at the dealer its 66 bucks for a brand new one.
Old May 8, 2006 | 08:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joeny12985 &raquo;</TD></TR><TR><TD CLASS="quote">main relay?!?</TD></TR></TABLE>
No chance
Old May 9, 2006 | 10:53 AM
whiteef-8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
No chance</TD></TR></TABLE>
so it aint the main relay you think
Old May 9, 2006 | 11:05 AM
so it aint the main relay you think</TD></TR></TABLE>
I know its not the main relay
Old May 11, 2006 | 10:21 AM
whiteef-8's Avatar
anyone know what it is?
hondaex99
Feb 5, 2010 10:34 AM
89hfstl
Nov 21, 2009 12:31 PM
J_J
18
Nov 22, 2006 10:45 AM
Evolution Type R
May 2, 2006 11:43 PM
JohnnieChimpo
Apr 24, 2004 08:27 AM
