will 92 integra seat fit in eg?
yes they will fit but only 3 of the 4 bolts will line up. You could swap the rail out of the eg and put them on the Integra seat and then all of the bolts will line up just nice.
Dave
Dave
yes he could of search but if you knew the answer you could of answered instead of putting a stupid comment like that.
Dave
Dave
thanks Dave. i did search. i couldn't find anything. there was a lot of 94-01 integra but none for 92s. just to let you know. thanks again.
btw. is it safe to ride on 3 bolts instead of 4?
alot of people have done it but the seat moves a little. Trust me just swap out the rail of your eg seat and you will be much more happier knowing that all 4 bolts are locking you in. It's a racing seat bolted with just 3 bolts do you think the driver feel safe knowing that one bolt is missing? If your going to do it do it right.
Dave
Dave
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93SiVtec677 »</TD></TR><TR><TD CLASS="quote">yes he could of search but if you knew the answer you could of answered instead of putting a stupid comment like that.
Dave</TD></TR></TABLE>
I didn't know the answer, sorry man. I would have not responded like had he said he already searched, but hey no one's perfect, my **** stinks too, apparently.
i look under the side molding and it looks like the rails are welded onto the frame. can someone clarify this for me please. is it weld or not.
do i have to remove carpets to swap the rails?
It may be a situation where they're bolted and welded, kinda like the hood brackets. If that's the case you can use something to bang it out. Someone correct me if I'm wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93SiVtec677 »</TD></TR><TR><TD CLASS="quote">alot of people have done it but the seat moves a little. Trust me just swap out the rail of your eg seat and you will be much more happier knowing that all 4 bolts are locking you in. It's a racing seat bolted with just 3 bolts do you think the driver feel safe knowing that one bolt is missing? If your going to do it do it right.
Yeah, I also got a ticket for that, "Unsafe Vehicle".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l »</TD></TR><TR><TD CLASS="quote">i look under the side molding and it looks like the rails are welded onto the frame. can someone clarify this for me please. is it weld or not.
do i have to remove carpets to swap the rails?</TD></TR></TABLE>
Nope, not welded.
Nope, not welded.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l »</TD></TR><TR><TD CLASS="quote">oh i see. do i have to remove the carpet in order to remove the rail? or can i just cut away the area around the rail and later the seat will cover it up.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOjdmHERE »</TD></TR><TR><TD CLASS="quote">just swap the damn rails, it isnt hard at all, just give it a try and youll be surprised how easy it is! good luck man!
it took me an hour to swap da rails on some del sol's dat i put in my hatch. NOT hard at all.
</TD></TR></TABLE>it took me an hour to swap da rails on some del sol's dat i put in my hatch. NOT hard at all.
does anyone read my post?
Powered By Garrett
Mar 26, 2005 08:29 PM
SOUNDEFFECTS
Nov 6, 2002 07:38 PM
