hasport motor mounts?
Old Apr 3, 2006 | 10:13 AM
95integraLS003's Avatar
Default hasport motor mounts?
On my 95 turbo'd LS im planning on getting Hasport motor mounts.. since the kit comes with 3 out of the 5 motor mounts (upper tranny, upper motor and firewall) should i worry about the other 2? my lower tranny one is shot, should i just get a oem one and leave it or put inserts in those lower ones as well? thanks
Old Apr 3, 2006 | 10:15 AM
DC4_MADMAN's Avatar
Default Re: hasport motor mounts? (95integraLS003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95integraLS003 &raquo;</TD></TR><TR><TD CLASS="quote">On my 95 turbo'd LS im planning on getting Hasport motor mounts.. since the kit comes with 3 out of the 5 motor mounts (upper tranny, upper motor and firewall) should i worry about the other 2? my lower tranny one is shot, should i just get a oem one and leave it or put inserts in those lower ones as well? thanks</TD></TR></TABLE>
With the hasports you shouldnt need the 2 lower torque mounts.
Old Apr 3, 2006 | 10:34 AM
SilverDc2's Avatar
Default Re: hasport motor mounts? (4door_demon)
dont worry the other two are torque mounts, their weak anyways, but if your concerned honda sells themfor cheap
Old Apr 3, 2006 | 04:01 PM
Default Re: hasport motor mounts? (SilverDc2-Ap1)
has anyone used the hasports on their turbo'd car without the lower torque mounts?
Old Apr 5, 2006 | 07:25 AM
so with the amt of torque increase from the turbo, should i put new stock lower ones anyways with polyurethane inserts? Anyone with turbo and hasports post pics!!
Old Apr 7, 2006 | 06:34 AM
anyone?
Old Apr 7, 2006 | 08:49 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95integraLS003 &raquo;</TD></TR><TR><TD CLASS="quote">so with the amt of torque increase from the turbo, should i put new stock lower ones anyways with polyurethane inserts? Anyone with turbo and hasports post pics!! </TD></TR></TABLE>
You don't "need" the lower mounts with the three upper hasports but it's not a bad idea to run the two lower with poly inserts for extra support.
Old Apr 29, 2006 | 08:31 AM
92-LS-Civic's Avatar
Default Re: hasport motor mounts? (skunked)
I agree. IF you have the money, go ahead and do the lowers. WOnt hurt to have them. But the hasport will most likely need no other support.
Old Apr 29, 2006 | 11:28 PM
AZSTATEPOLICE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95integraLS003 &raquo;</TD></TR><TR><TD CLASS="quote">has anyone used the hasports on their turbo'd car without the lower torque mounts?</TD></TR></TABLE>
Yes and for lower mounts. No need.
Old Apr 30, 2006 | 12:58 AM
quikflip27's Avatar
my car isnt turbod yet, but i have those three mounts in, and new oem lower mounts. you wont need anything more than the hasports, they are already really rigid and are alot storonger than other welded mounts. just be weary that there is vibration coming your way
quikflip
Old Apr 30, 2006 | 04:11 AM
LL2009's Avatar
Default Re: (quikflip27)
i will used then, but dont buy new ones just get the inserts for then .
h22civicek
Feb 18, 2009 11:06 AM
NAmodified
Oct 16, 2007 08:35 AM
SPOOLINmatt
May 30, 2007 06:03 PM
spooledhonda
Jan 1, 2007 07:35 AM
Jamied
10
Mar 29, 2006 06:31 PM
