idle problem w/ h22 eg
Old Apr 3, 2006 | 09:04 AM
Terrible One's Avatar
Default idle problem w/ h22 eg
93 civic w/ obd1 jdm h22a running auto p13
the problem is common, after the motor warms up it has a surging idle where the rpm's would go up and down between 1000-1500. ive ready read through numerous threads on how to fix it by cleaning out the iacv or tightening the screw in the fitv. ive performed both tasks and completed with bleeding the coolant system but still ended w/ the same surging idle. not to long ago i got a hold of a chipped p06 w/ an h22a basemap. with this ecu the motor runs normal w/o any surging idle, only problem is that vtec support wasnt properly installed onto the ecu so i have no vtec (throws code 21). im wondering why my chipped p06 doesnt cause the surging idle but my p13 does.
ps: the p06 doesnt have iab support.
Modified by Terrible One at 10:58 AM 4/5/2006
Old Apr 3, 2006 | 08:49 PM
Default Re: idle problem w/ h22 eg (Terrible One)
bump
Old Apr 4, 2006 | 07:14 AM
up
Old Apr 4, 2006 | 09:22 AM
ttt
Old Apr 4, 2006 | 08:54 PM
help
Old Apr 5, 2006 | 06:05 AM
need suggestions
Old Apr 5, 2006 | 08:55 AM
upp
Old Apr 5, 2006 | 09:56 PM
ttttttt
Old Apr 6, 2006 | 06:05 AM
bump?..........72 views
Old Apr 6, 2006 | 03:51 PM
dahoopdahup's Avatar
Well since no one will respond I will give my two sense. I did a swap in my buddys accord and had a similar problem. Found out the egr was screwing it all up so I just disconected the vacum line and all beter. Beter than no advice right???? hope u figure it out.
Old Apr 6, 2006 | 04:51 PM
b_serious's Avatar
Default Re: idle problem w/ h22 eg (dahoopdahup)
mine was intake mani gasket, then throttlebody gasket
gmuas
Mar 6, 2008 12:58 PM
worrdogg
Nov 4, 2004 03:09 PM
worrdogg
Nov 4, 2004 12:16 PM
aaaabbbb
Jul 8, 2004 01:17 PM
tylek17
Jan 29, 2004 08:12 PM
