assembling the rocker arms
Old Apr 3, 2006 | 08:23 AM
kikoy's Avatar
Default assembling the rocker arms
pls. help.. does anybody know were does the rocker arm shafts face when installing in the head? on the other end of the shaft it has ang indented part and on the opposite it has a flat side. which side of the shaft gets in the head going to the distributor ang the vtec selenoid? pls help..
Old Apr 3, 2006 | 09:39 AM
DonF's Avatar
Default Re: assembling the rocker arms (kikoy)
Flat ends to the front. You must line up the holes for the oil restrictors, in the front of the head.
Old Apr 5, 2006 | 01:25 AM
kikoy's Avatar
Default Re: assembling the rocker arms (DonF)
you mean that the oil ristrictors must be inserted in the shaft holes? the indented side will go to the distributor and the vtec selenoid? thanks for the reply Donf.
raverx3m
Jan 31, 2015 09:56 AM
blacc9
Mar 9, 2007 03:41 PM
