Do i need anyhting else???
Old Apr 3, 2006 | 07:49 AM
swap0em5out's Avatar
Default Do i need anyhting else???
I am buying a Jdm b16 swap from a guy in memphis tomm. and was wondering what ither things i need to put the swap in my 89 CRX HF., I'm pretty sure i dont have to make any engine bay room...
Ok so i have the complete B16a2 motor, hydrp trans, ecu, axels, wire harness, b-series motor mounts for hydrolic transmission. and what ever shiftlinkage comes with the transmission.
Do i need a conversion harness to obd1 given its an obd1 motor. Will i need a new shiftlinkage. Do i need a cable to hydro transmission conversion?
Right now i have a 96 civic dx motor in it now with stock HF transmission and distributor???please help....thanks in advance
Old Apr 3, 2006 | 07:56 AM
djphonics's Avatar
Default Re: Do i need anyhting else??? (swap0em5out)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swap0em5out &raquo;</TD></TR><TR><TD CLASS="quote">I am buying a Jdm b16 swap from a guy in memphis tomm. and was wondering what ither things i need to put the swap in my 89 CRX HF., I'm pretty sure i dont have to make any engine bay room...</TD></TR></TABLE>
You gotta hammer out a small spot for the alternater to fit.
Old Apr 3, 2006 | 04:46 PM
i thought that the room was only need if i was putting a gsr swap but since its a B16 it wasnt needed
Old Apr 3, 2006 | 04:52 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swap0em5out &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure i dont have to make any engine bay room...</TD></TR></TABLE>
All B-series swaps require hammering a dent into the frame rail to make room for the alternator pulley.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Do i need a conversion harness to obd1 given its an obd1 motor.</TD></TR></TABLE>
The B16A2 is an OBD-2 engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Will i need a new shiftlinkage. Do i need a cable to hydro transmission conversion?</TD></TR></TABLE>
Yes, and yes.
You're also going to need front suspension knuckles from an '88-91 DX, LX, EX, or Si. HF and STD knuckles cannot be used with B-series axles.
Old Apr 3, 2006 | 08:15 PM
yeah i meant obd2 conversion harness....where is a good place on the internet to get the suspension products or should i just get someone to order them from town???
I have a vis cf zc hood that wouldnt matter in this swap as far as head room goes would it?
thanks
swap0em5out
Feb 7, 2006 06:39 AM
Beau Gotti
Jan 4, 2006 05:27 PM
ironchef25
10
Oct 29, 2003 09:14 AM
CRX A4
Feb 18, 2003 07:25 AM
98acura
Jan 14, 2003 10:30 AM
