DC2 Making Funny Noise Need A Diagnosis
Old Apr 3, 2006 | 07:39 AM
R-81DC2's Avatar
Default DC2 Making Funny Noise Need A Diagnosis
My car makes like a scrapping sound, like hair cutters buzzing, or like metal touching metal- When the car is between 3,000 and 4,000 rpm's and the loudest at 3,500 rpm's. The sound is coming from the passenger's under the hood-motor/tranny and it is heard when ever the rpm's reach that point, whether its in neutral and im revving it or im just driving regular.
Modified by R-81DC2 at 9:05 AM 4/3/2006
Old Apr 3, 2006 | 07:52 AM
R-81DC2's Avatar
Default Re: DC2 Making Funny Noise Need A Diagnosis (R-81DC2)
Im thinking it has something to do with the flywheel
Old Apr 3, 2006 | 08:29 AM
Arsenal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-81DC2 &raquo;</TD></TR><TR><TD CLASS="quote">Im thinking it has something to do with the flywheel</TD></TR></TABLE>? If you are going to say something like that say why.
Sounds more like heat shield, fairly common problem. The bolts get old and loosen up just a little to cause a vibration, hence metal on metal.
Old Apr 3, 2006 | 08:42 AM
GSRintegra_Bob's Avatar
It does sound like a heatshield problem... I took all mine off and no more rattles... try it and see if it helps
Old Apr 3, 2006 | 09:44 AM
iH8RICERZ's Avatar
Default Re: (GSRintegra_Bob)
I had the same exact problem at the same rpm....found out that my header-to-cat bolts were a little lose. Tightened those bolts and that loud buzzing/metal to metal noise was gone.
Old Apr 3, 2006 | 10:08 AM
ajantics's Avatar
Default Re: (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">I had the same exact problem at the same rpm....found out that my header-to-cat bolts were a little lose. Tightened those bolts and that loud buzzing/metal to metal noise was gone.</TD></TR></TABLE>
I had the same thing happen to me. I thought is was apexi cat back and was flamming pissed! Then I relized that I was a idot and didn't tighten the bolts
Old Apr 3, 2006 | 10:17 AM
Taristin's Avatar
My DC4 had that a few months back, a metal rattling sound. Was the heat shield. Tied some metal string around it and it went away.
Old Apr 3, 2006 | 11:07 AM
R-81DC2's Avatar
Default Re: (Taristin)
The heat shield for the cat, right?
Old Apr 3, 2006 | 11:37 AM
SlamminS85's Avatar
Default Re: (R-81DC2)
i had the same buzzing, it was the heatshield in front of my block that covers up the header
Old Apr 3, 2006 | 12:24 PM
SlammedDC2teg's Avatar
Default Re: (SlamminS85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-81DC2 &raquo;</TD></TR><TR><TD CLASS="quote">The heat shield for the cat, right?</TD></TR></TABLE>
yes thats it. i had the same problem.
Old Apr 3, 2006 | 04:46 PM
R-81DC2's Avatar
Default Re: (SlammedDC2teg)
jus finished typing a paper bump
RKSskier
Feb 4, 2010 02:12 PM
bay_DA
Oct 9, 2006 06:52 PM
WhoDoYouThink
Feb 16, 2006 08:09 AM
Type-Rare#1248
Sep 19, 2004 09:34 PM
projectTeG
Mar 4, 2004 10:27 AM
