side marker question(blinker sync)
Old Apr 3, 2006 | 07:25 AM
lv6l's Avatar
Default side marker question(blinker sync)
is there any possible way to make the corner blinker and the sidemarker sync on an EG civic?
Old Apr 3, 2006 | 07:53 AM
vtakvtrak's Avatar
Default Re: side marker question(blinker sync) (lv6l)
you could split ur corners and have it wired to sidemarkers too.
Old Apr 3, 2006 | 08:24 AM
lv6l's Avatar
my question was can you make them sync.(blink at the same time)
i know i can connect them to my corners but i've seen many before and they never blink the same time. so i was .
Old Apr 3, 2006 | 02:05 PM
slowpokecivic's Avatar
Default Re: (lv6l)
yea you can...theres a link in the FAQ section that tells you how...
Old Apr 3, 2006 | 02:09 PM
Padawan's Avatar
Darth ModerVader
If you wire the side markers to the turn signal wires, they will flash at the same time. The only time they alternate is when they are wired up "ricer style", since they are constantly illuminated when the parking lamps are switched on, and then switch off when the turn signal flashes.
Old Apr 3, 2006 | 07:27 PM
lv6l's Avatar
i herd that its either or. either blinkers only or parking lights only. never herd you can have both. what do you mean by wired up "ricer style"
Old Apr 3, 2006 | 07:42 PM
Padawan's Avatar
Darth ModerVader
Default Re: (lv6l)
"Blinkers only" is the correct way to wire them, and if wired this way, they will blink at the same time that the turn signals do. What I referred to as "ricer style" is when the side markers are wired to both the turn signal and parking light leads. This results in side markers that illuminate when the parking lights are on and switch off whenever the turn signal flashes.
Old Apr 3, 2006 | 08:38 PM
eastbay925's Avatar
Default Re: (Padawan)
when I installed mine i counldn't get them to do both, right now they stay on and don't blink when i use the turn signals
Old Apr 3, 2006 | 08:44 PM
Josh C.'s Avatar
Default Re: (eastbay925)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastbay925 &raquo;</TD></TR><TR><TD CLASS="quote">when I installed mine i counldn't get them to do both, right now they stay on and don't blink when i use the turn signals</TD></TR></TABLE>
haha! I like it. ^
Old Apr 4, 2006 | 03:59 AM
Padawan's Avatar
Darth ModerVader
All you need to do is tap into the turn signal wire and a ground wire, and your side markers will function properly.
Old Apr 4, 2006 | 06:07 AM
lv6l's Avatar
which is the turn signal wire?
Old Apr 4, 2006 | 06:55 AM
Padawan's Avatar
Darth ModerVader
Default Re: (lv6l)
I don't know the actual color of the wire, but (at the risk of stating the obvious) it's the one connected to the turn signal.
fryman
12
Nov 7, 2011 09:42 AM
BadassEFdriver
Sep 1, 2010 03:21 AM
idriveadelsol7
10
Jun 19, 2005 09:18 PM
Nextelbuddy
Feb 28, 2005 06:45 AM
XxSOHCDriVerxX
Jun 7, 2003 12:15 AM
