choking in low revs
Old Apr 3, 2006 | 02:14 AM
louis_c's Avatar
Default choking in low revs
Hi, I have a problem with my CRX ED9. This problem doesn't occure regularly...no ECU error... example: I stop the car on the crossroad. I shift the 1st gear and accelerate... when I reach 2000 rpm car starts to choke and there is no response to additional push of gas pedal... after 5 sec it is ok.... it also happens when I need to slow down and shift down to 2nd gear...
I have replaced sparks, plugs, air filter, MAP sensor, distributor, oxygen sensor... I have cleaned thr. body, EACV, checked the vacuum lines..... what could be wrong? it really drives me crazy....
Old Apr 3, 2006 | 04:57 AM
Autoworks's Avatar
Default Re: choking in low revs (louis_c)
My guess would be either O2 sensor, fuel filter or fuel pump. Choking from a bad O2 reading or lack of fuel at 1 point.
Check your timing too.
Old Apr 3, 2006 | 10:33 PM
louis_c's Avatar
Default Re: choking in low revs (Autoworks)
Thanks
acmoc
Dec 26, 2015 03:20 PM
mondiex
Jun 15, 2012 11:00 AM
Kuniva
Feb 26, 2009 07:27 AM
Ed 341
Jul 17, 2006 06:24 PM
MidwestSi
Jun 23, 2005 05:43 AM
