Supertech 1mm valves and Buddy club V cams ???
Has anyone used supertech 1mm valves with buddy club V cams... or do i have to sell the valves and get a stock size.... need to know soon im sending the head out to get done... also using supertech 12.5.1 pistions in a GSR motor and should i be using flat or dish valve??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93-lsvtec-eh2 »</TD></TR><TR><TD CLASS="quote">yeah i have stock size valves and i'm having problems with valve to valve clearance</TD></TR></TABLE>
what cams ?
what cams ?
I ran the buddy 5's with a 1mm oversize intake valve.. I couldnt move my cam gears at all.. If i tried to move them 1 degree the valve would hit each other.. The low lift duration is huge on them so the valve to valve is to close. I had alot more room with the skunk pro-3's actually..The ex cam on the buddy 5 is one of the largest ones I have seen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Squrtin DC2 »</TD></TR><TR><TD CLASS="quote">
what cams ?</TD></TR></TABLE>
bc5's
bc5's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Squrtin DC2 »</TD></TR><TR><TD CLASS="quote">how do you think those cams on stock valves and like a 250+ shot would do ?</TD></TR></TABLE> for nitrous you want a cam with low duration. look into buddy club 3+ or skunk stage 1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KINGSOL18 »</TD></TR><TR><TD CLASS="quote"> for nitrous you want a cam with low duration. look into buddy club 3+ or skunk stage 1</TD></TR></TABLE>
why ? can i do the 3+ with 1mm valves ?
i would go with a smaller cam bc5's have a huge amount of duration so there might be a chance of you burning a valve or some other damage. just stick with the 3+ or something close to it in size
hothondagurl
Oct 23, 2011 03:38 PM
