Texas -OK -LA (Sales) Texas, Oklahoma, Louisiana
MEGA BUILT TURBO D16 SALE! Ram horn; forged pistons rods; Safeguard; TURBO PARTS
Old Apr 2, 2006 | 08:55 PM
Pay2play killa's Avatar
Default MEGA BUILT TURBO D16 SALE! Ram horn; forged pistons rods; Safeguard; TURBO PARTS
Ok guys; this is Version 3 of my ultra for sale thread. I need to get rid of most of it so i can finance my relocation out of this town Please buy something and help a brotha out
So i killed my last D series. took out a rod bearing when my wastegate line came off; boost cut was set too high. not enough oil to keep #4 rod from beating up the bearing. it's not spun but its beat up.
I have a b18a1 i'm building up now so i'm selling all my D parts. Here they are:
Current parts that were in the car:
75 - D16z6 block with endyn block posts - crank needs turning no internals
275 - J&S Ultra Safeguard - with monitor and gm universal knock sensor - Individual cylinder knock control; great tuning aid keeps the motor from knocking by pulling timing from whatever cylinder is knocking
other D-series and random parts:
60 - d16z6 head in pieces needs some valves and vtec solenoid
50 - d16a6 head mostly complete has cam and all valves/springs but no manifolds or distro (was backup head)
50 - d15b2 shortblock - good (was my backup motor)
40 - d15b2 head complete - no manifolds or distro
20 - d16y7 intake manifold - missing tps
5e 20 for all - 6x -d16 rods w/ bad pistons
20 - stock d-series flywheel
25 - cable dx transmission - needs rebuild - swapped it out with above trans
40 - EF D-series shift linkage with short throw shifter
75 - Brand new autozone reman axles, just swapped out using lifetime warantee
50 - EG Half rad w/ cap
50 - B18A1 LS rods - 4 rods in great shape w/ original bearings with 3 bad pistons - estimated millage < 50k
40e - 2x 1g dsm SMIC
25e - 2x 1g dsm smic cores
20 - Autometer phantom mechanical oil pressure gauge w/ fittings and hardware - needs cleaning of the inlet the needle sticks some times, i think some teflon got stuck in there. I've cleaned it once with success
40 - Autometer phantom air/fuel pressure gauge used but great shape
30 - Autometer phantom electrical water temp gauge comes w/ hardware but NO sender used but great shape
40 - Autometer phantom elecrical EGT gauge and pyrometer probe - no control box - works AFAIK but without a box to test it i'm unsure (model 5765-1074)
15e - 4-obd0 d16a6 peak-n-hold 240cc injectors
15 - 4-obd1 ls saturated 240cc injectors
Non-honda parts:
175 - Pioneer SX-315 home theater in a box thing
100 - RadioShack Pro-95 dual trunk tracking scanner - well used but in good shape
Sold items:
SOLD - 50-D16a6 block w/ crank needs turning
SOLD - 60-D16A6 or d16z6 arp head studs
SOLD - 35-JG Engine dynamics D cam gear with key
SOLD - 175-Old style tuner toys/knockoff h beam rods - 77mm end cap can be shaved down to fit 75 or 75.5mm bore; NEW UNUSED with arp hardware
SOLD - 10-cable crx hf 4spd - probably good - was in car when i bought it; took it out when i got above tranny
SOLD - 40 - Autometer phantom mechanical 30" - 20psi boost gauge - used but great shape comes w/ hardware
SOLD - 60 - Knockoff SSauto/XS power 35mm wastegate - 4 or 8psi spring your choice. Used but in great shape; bought it as a spare; dont need it now. Does not come w/ ring seat or flanges, new ones are $20 for a tial 35mm and they will fit
SOLD - 20 - stock d-series clutches w/ pressure plates - little to no wear
SOLD - 25 - Japanese 10.3mm tripple core plug wires for D16Z6 but will fit other D's. less than 500mi on them - great wires
SOLD - 75 - Good condition 14b turbo no shaft play no evidence of oil leakage
SOLD - 125 - rebuilt cable d-series dx transmission - was in car less than 75 miles since rebuild - replaced a few worn bearings and input shaft seal; swapped out some syncro's from another tranny; swapped out the diff etc.
SOLD - 190 - XTD stage 3 clutch practically new w/ XTD 8lb flywheel - installed w/ rebuilt trans < 75 miles; not even broken in; never abused as its not broke in - great clutch love the light flywheel
SOLD - 150 - 8.5:1 D16Z6 SRP forged pistons std bore with rings (will get pics as soon as their out of the car)
SOLD - 175 - Eagle H beam D16 rods 3 good 1 iffy - arp200 rod bolts - the better ones (will get pics as soon as their out of the car)
SOLD - 40 - 12" elecric slim fan
SOLD - 75 - Dodge Neon half sized short radiator w/ slim fan filler neck and hoses - fits like eg half rad but not as tall.
SOLD - 230 - d16z6 head complete w/ intake, B16 tb, obd1 distro, B&M fpr, - was in car - springs/valves were matched up, valve job done; NGK 1 step colder plugs with < 1k mi - will come w/ cam gear and z6 belt - great for mpfi/mini-me swap
SOLD - 60 - OBD0-OBD1 conversion jumper harness - built to your specs (meaning i have the parts and will build it if you want it)
SOLD - 250 - D16 ram-horn t3 flanged turbo manifold - internal gated turbo; external waste gate flange can be added for a fee - garunteed not to crack - built by myself. Works great; ~ 5k miles on it so far; no cracks no major problems. If it gives you trouble i'll fix it I promise. I'm mostly just recovering my costs out of it - true collector semi equal length design MIG welded w/ stainless wire - Flows much better than a Log
Please note prices ARE NOT shipped and ARE NOT set in stone; i'm open to offers or package deals. I have a number of vouches on here; i've bought and sold from a number of people. I also have Ebay with 115 or so all posative feedbacks (username TSAudio). I am paypal verified with all posative feedback. you can reach me via pm here but i'd prefer you aim me at "honda of fury"
ALSO: IF YOU BUY SOMETHING AND ARE NOT SATISFIED I WILL WORK WITH YOU.
Here are a few pictures, more are in my photobucket:
DSM SMICs
Posted block
Photobucket here:
http://s37.photobucket.com/alb...stuff/
Some trades I would accept are:
-B16 Cylinder head complete minus manifolds
-LS forged pistons (low compression)
-Any LS buildup parts really
-b series cable trany or
-LS aftermarket clutch/flywheel
-ETC b series parts
-EF B series swap parts (mounts/axles/shift linkage/etc)
XXX - LS forged rods
xxx - vtec b series oil pump
Modified by Pay2play killa at 11:10 PM 4/30/2006
Old Apr 4, 2006 | 11:53 PM
Default Re: MEGA BUILT TURBO D16 SALE! Ram horn; forged pistons rods; Safeguard; TURBO PARTS (Pay2play killa
ttt
Old Apr 8, 2006 | 02:52 PM
TTT
Old Apr 10, 2006 | 05:07 PM
bizzump...
Buy stuff so i can pay bills
Old Apr 15, 2006 | 11:34 PM
bump
Old Apr 18, 2006 | 07:37 PM
up
Old Apr 20, 2006 | 08:51 PM
good z6 head and neon rad sold
Old Apr 23, 2006 | 09:57 PM
TTT w/ u
Old Apr 30, 2006 | 08:10 PM
updated
Old Jun 1, 2006 | 10:05 PM
last bump
theeMFkilla
Feb 3, 2013 10:08 AM
KENetics1
Aug 24, 2012 06:17 AM
dustinbs144
May 31, 2010 09:17 AM
Pay2play killa
Jun 1, 2006 10:04 PM
