cam degreeing ?
if...
you set the cams by the timing marks, then set them to the setting which makes the most power on dyno
will they be in the same position if...
you set the cams by degreeing, then set them to the setting which makes the most power
hopefully breaking the question up like this will help clear any confusion as to what exactly im asking. in my mind, the answer is yes, becasue the same motor will make the most power at the same cam settings, so in the end, it wont matter if you degree or go by the timing marks, if you dyno tune it. correct?
kefka
Apr 6, 2004 04:54 PM
