window won't go up
94 accord. passenger front window went down then, later, refused to go back up. from drivers master switch panel and from the passenger doors switch panel there is no response. when I press to go down, I can hear the motor pulling current but there is absolutely nothing when trying to go up.
I put direct power to the motor and it went up no problem. used the switch to pull it back down, direct power and it went up again.
so, I'm assuming it's not the motor and I doubt that both the drivers master window switch and the passenger window switch broke on the down function at the exact same time.
what do I check next?
thanks.
thanks.
have a similar issue on my passenger window
both driver and passenger can roll window down.
passenger cannot roll window up, driver can roll window up.
driver cannot roll window up when passenger is trying to roll it up at same time (ie both driver and passenger are pushing up on the window switch)
bump for answers
bump for answers
remove the master switch.........take apart the passanger switch,the one on the master switch,, clean the contacts ,, sometimes they get dirty and pitted.. get some sand paper and clean them.. careful not to lose the little springs..put a bit of greae to keep them in place when putting it together ..try it ,see if it helps..
if not, do the same to the rt side switch,, .
.if cleaning does not help you might have issues with the p/w control unit ..
gsaldana10
Honda Civic (2001 - 2005)
May 16, 2017 08:47 AM
robwilhelm
Sep 19, 2007 10:05 AM
