89 crx si cluster into 89 civic dx
Old Apr 2, 2006 | 05:28 PM
exsinnovation's Avatar
Default 89 crx si cluster into 89 civic dx
could i get some help please??? are the 89 crx si cluster pin outs the same as 91 crx si clusters? i need some help installing the 89 crx si cluster into my 89 DX. and yes they are different! the 89 crx si has the seat belt indicator is inbetween the gas and temp gauges.
Thanks in advance..
Modified by exsinnovation at 1:52 AM 4/7/2006
Old Apr 2, 2006 | 05:31 PM
PrestonCRX's Avatar
Default Re: 89 crx si cluster into 89 civic dx (exsinnovation)
i have a 88 crx gauge cluster in my 89 std it works fine it was a plug and play deal
Old Apr 2, 2006 | 05:45 PM
89!!!!!! crx si has seatbelts on doors!!!
Old Apr 2, 2006 | 09:26 PM
I would really appreciate it if i could really get some help
Old Apr 2, 2006 | 09:32 PM
Eaglekper0046's Avatar
Default Re: (exsinnovation)
Yes it plug and play. My 90 has seatbelts on the doors. Ive had about 5 different cluster in my car. Everything worked fine.
Old Apr 2, 2006 | 09:38 PM
crxnj's Avatar
Default Re: (Eaglekper0046)
Yup,its plug and play for an 89 crx si cluster into an 89 civic dx..
Old Apr 2, 2006 | 09:40 PM
does your cluster have the seat belt light inbetween the temp gauge and the gas meter????
Old Apr 2, 2006 | 09:47 PM
crxnj's Avatar
I have 89 crx si and the yes the seatbelt light is between the temp and fuel gauge..
Old Apr 2, 2006 | 09:54 PM
is the cluster in a crx si or in a civic Dx????
Old Apr 2, 2006 | 09:57 PM
crxnj's Avatar
Its a 89 crx si with the stock cluster..
Old Apr 2, 2006 | 10:02 PM
does anyone have the 1989 Honda Crx cluster in a 1989 Honda Civic Dx? its not plug and play i believe the 89 crx si has the same pin outs as a 90-91 crx si. just the shape gets changed 90-91. my crx si cluster isnt working properly in my 89 civic dx the rpm doesnt work along with everything else on the cluster it only lights up........
Old Apr 2, 2006 | 10:19 PM
i just want to know if the pin outs are the same as 90-91
Old Apr 2, 2006 | 10:22 PM
crxnj's Avatar
89/89 is different then 90/91..
Old Apr 2, 2006 | 10:26 PM
than why doesnt the 89 crx si cluster work in my dx?
Old Apr 2, 2006 | 10:33 PM
crxnj's Avatar
Maybe you have the wrong cluster..I dont mean years or anything..But there were 2 different companies that made the cluster in 88/89...1 is stamped NS and the other is stamped something else..I forget exactly what the other stamp is..But you have to use the same one that your car came with..
Old Apr 3, 2006 | 06:07 AM
really??whats the other stamp??? that kinda sucks.. whats the difference between them? pin outs?
Old Apr 3, 2006 | 10:16 AM
crxnj's Avatar
Ok..I searched it and found the other stamp is "ND"
Old Apr 4, 2006 | 01:12 PM
so im guessing the ns is the one i need! FOR SALE 89 crx si (brand ND) CLUSTER!!!
Old Apr 4, 2006 | 03:11 PM
SupraRXZ's Avatar
would a 90 si plug and play on a 90 HF?
Old Apr 5, 2006 | 12:07 AM
probably. i dont think they made 2 different clusters so youll be ok. but i need a 88-89 NS cluster~!
Old Apr 6, 2006 | 03:13 PM
wood 1's Avatar
Have you found a solution to your cluster problem yet? I read this days ago but could not log in for some reason. Finally just registered again so I could correspond on H-T. Itried to get help to go back to my originaluser name, but noone wanted to help.
If you haven't solved the problem post up and I will try to help you. Ibelieve in helping others unlike most in this forum do. Sorry to complain, let me know if you need help.
Sorry I won't be able to help you today, I already have my 5 NOOB posts for the day! If you respond, I'll catch you tomorrow, hopefully in my 5 posts.
Dan
Thanks dfwaccord for prooving what I have said in the past. All same year clusters ARE NOT plug and play! Asyou can see from your pictures, the first noticable difference is that the NS (nippon Seiki) has 3 plugs, and the ND ( Nippon Denso) has 2 plugs. This 2nd paragraph is in response to the post below,because having to register again, I only get 5 posts per day!!!!! 19 more days and I will be a normal user again! Yahooooo!
Modified by wood 1 at 5:11 PM 4/6/2006
Old Apr 6, 2006 | 03:20 PM
marquisdee1018's Avatar
Default Re: (wood 1)
They are different. Here are the backs. Both are from an 89 CRX. The one on the top is stamped NS and the one on the bottom is stamped ND
Old Apr 6, 2006 | 04:48 PM
so you can use only either or???
Old Apr 6, 2006 | 04:50 PM
and is it possible to get the NS to work with my car that originally had a ND???
Old Apr 6, 2006 | 06:46 PM
My car came with the ND and I couldn't get the NS to work in it. Everything plugs in but the tach didn't work and the check engine light came on.
