idling issues with pro 1 cams
i know that a lumpy idle is a given with these cams, but i'd like to try to reduce it. i've been using crome and it seems to like idling at around 15-16 afr. is this normal? what amount of timing should i be using at idle? i tried to raise idle with crome, but that feature doesn't work
Close the throttle body stop all the way (allen screw with nut), and open it up a slight slight hair. Set tps to .45 volts. Set the fuel pressure to 45 at atmospheric pressure, (vaccuum hose off). and timing at 16 degrees up to 1000 rpms. And set the throttle body adjustment screw to stock, or close to it.
when the throttle plate is opened more than this with big cams, it can be a real PITA to get it to idle.
I didn't have any issues.
85mm dart block
12.8:1 compression
ported head
Skunk2 Pro1s
50mm TWM ITBs
Hytech header
42lb (440cc) mustang cobra injectors @ 68psi static fuel pressure driven by walbro 255
Had car idling at 850 RPM without any major issues. Idled a little on the rich side - 13.8:1 AFR. Timing was NOT 16 degres, wanna say closer to 20 or so. Ended up raising idle to ~950-1000 RPM per request of customer.
85mm dart block
12.8:1 compression
ported head
Skunk2 Pro1s
50mm TWM ITBs
Hytech header
how does he like the pro1's? i was using bc3+ before and i'm kinda dissapointed with the pro1's right now, hope it gets better when i get it fully tuned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JerseySiPOS »</TD></TR><TR><TD CLASS="quote">Close the throttle body stop all the way (allen screw with nut), and open it up a slight slight hair. Set tps to .45 volts. Set the fuel pressure to 45 at atmospheric pressure, (vaccuum hose off). and timing at 16 degrees up to 1000 rpms. And set the throttle body adjustment screw to stock, or close to it.
when the throttle plate is opened more than this with big cams, it can be a real PITA to get it to idle.</TD></TR></TABLE>
Has any else done this???
The way my tuner got my car to idle ended up being by adjusting the throttle stop up a hair, and giving it 22 degrees of timing at idle.
Idle's great now.
This is with Pro2's by the way.
Also, my valvetrain louder than a stock Honda. If I adjust it any tighter, it doesn't stay running.
Idle's great now.
GetawayInMoscow
Nov 24, 2006 09:59 AM
JCushing
11
Aug 22, 2005 04:48 PM
Used2beAb16
Mar 30, 2004 02:57 PM
