need help plans to swap head put a d15b7 (dx) head on a d15b8 (cx) motor
need help in things involved in the process of swaping heads
its my first project ever and ineed all you guyz help just bought some tools and stuff like clutch and flywheel need info on what else i need to buy and this is what i'm gonna do .................
changing my d15b8 8valve head with a d15b7 16 valve head need to change the headgasket please help me what i should do to make the necessary things what all should i watch out for and also what kind of seals i need to buy
i'm also planning on changing the clutch and flywheel as i will be pulling out the motor so need the torque specs and also the sequence for the head studs and things like that
please fellows need help and info on everythin i need to do ok
i would suggest getting a helms manual for your year civic. it tells everything. Or at the least, get the haynes manual from auto zone.
