91 Si B16 Problem
Old Apr 2, 2006 | 03:32 PM
91-lsvtecsi's Avatar
Default 91 Si B16 Problem
another problem i got in 91 si with b16
motor is shaking at idle only, motor is running strong, the car is studdering a bit around 800k til 1500k affter that car is running like a champ- i changed the plugs,wires,cap,rotor and still shaking, i checked my mounts they looks good. my next thing to change is the fuel filter, my question to u guys is WTF is goin on wit my car?? can the alternator cause this problem? i have a small sub in my car and i just wired it up and i see the idle droppin when listening to music , yea yea i dunno either but i hope you guys can help me thanx !
Old Apr 2, 2006 | 04:25 PM
Default Re: 91 Si B16 Problem (91LSVTECSI)
bump
Old Apr 2, 2006 | 07:17 PM
help
Old Apr 2, 2006 | 07:23 PM
MightyMouseTech's Avatar
Sounds like you have a vacuum leak.
Old Apr 2, 2006 | 11:54 PM
thank for the reply i will let you know first thing in the morning. where should i check for the vacuum leak
Old Apr 3, 2006 | 05:19 AM
princess24's Avatar
Default Re: (91LSVTECSI)
check in the intake manifold gasket those seem to go bad on b16 alot
Old Apr 3, 2006 | 06:16 AM
well last night at work i threw on a clear dizzy cap i got froma friend. so i checked the spark and i have no to weak spark in cylinder #4 , i pulled the plug for the 4th cylinder and no change in idle, pulled 3 and motor changed idle- so far i changed,plugs,wires,cap,rotor i dunno wat to do HELP
Old Apr 4, 2006 | 09:07 PM
stockbee's Avatar
excuse my former reply, I think I put it in the wrong thread obviously....forgive me.
Modified by stockbee at 8:31 AM 4/7/2006
Old Apr 6, 2006 | 09:56 AM
Default Re: (stockbee)
Do a compression test on that cylinder, I bet you have a bad valve....time for a head job.
Old Apr 6, 2006 | 12:52 PM
Default Re: (MightyMouseTech)
well here are the number 65 215 220 215 there u go!
Old Apr 8, 2006 | 05:14 PM
well i had two bent valves on the intake side, picked up some type r valves from a local h-t member and gonna install the head 2orrom wish me luck!!
Old Apr 10, 2006 | 06:05 AM
After you rebuild it, try not to miss any more shifts.
Old Apr 10, 2006 | 06:42 PM
hmmmm nevered missed shift but bump
nousername
29
Dec 29, 2009 03:17 PM
WWTeg
Mar 9, 2008 05:00 PM
(760)doogie
Apr 17, 2007 01:35 PM
91-lsvtecsi
14
Apr 7, 2006 07:26 AM
ek_slut
Jul 15, 2005 02:15 PM
