Sway Bar Endlink/bushing Questions???
When installing the front and rear ST swaybars....How tight do u tightn the endlinks??? Basically how tight is to tight? When i first installed them around last november...i didnt know how tight to get them...but right now they are pretty squished! and i dont think thats right...i mite need replacements too....
So if anyone knows where i can get new bushings or endlinks..please post! i just want to be sure i do it right the second time!
Thanks!
Oh and this is for a 1994 integra gsr!
Thanks!
the endlinks should be touching the swaybar, but not tight, not mushroomed out. ill see if i can find a picture that has how they are supposed to be.
if you need replacements, try summitracing.com. they carry pretty much all ST's products
*edit* https://honda-tech.com/zerothread?id=1479411 and http://www.hadamotorsport.com/....html both of those have decent examples of how tight the endlinks should be
Ahh ic thanks.....yeh mine looks nothing like that lol..well dam ill have to redo them with some fresh bushings....
Whats the disadvantages of having them mushroomed??? How much does it effect the drivability and handling?
Thanks!
Thanks!
when you install everything.. such as the sway bar bushings and such... dont tighten everything down until the weight of the car is resting on the bushings.. then tighten until the bushings begin the squeeze out
