Will B16a Injectors fit a D16a6 also the TB
I have a B16A complete head laying around and was wondering if I could use the injectors in a D16 for running turbo. Also the Throttle body looks to match up just nice but will everything run normal. Anyone know specs of B16 TB over D16 it looks a couple MM bigger.
Any way if anyone knows of the injectors working that would be great.
The b16a injectors flow the same as the d16a6 injectors..Yes they will work though,,Assuming they're obd0,,if obd1 then they are saturated and the resistor box will need to be removed....
Throttlebody Im unsure of..I know b-series bolt up to the 92+ d-series manifolds ,,but not sure about the d16a6 manifold..And the b16 is 60mm..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">The b16a injectors flow the same as the d16a6 injectors..Yes they will work though,,Assuming they're obd0,,if obd1 then they are saturated and the resistor box will need to be removed....
Throttlebody Im unsure of..I know b-series bolt up to the 92+ d-series manifolds ,,but not sure about the d16a6 manifold..And the b16 is 60mm..</TD></TR></TABLE>
He's right. The injectors flow the same so its pointless unless u don't have injectors. Also, the TB will only work with y8 and z6's i believe.
SpOoLiNg CiViC
18
Apr 28, 2006 03:33 PM
