koni yellow inserts?
Old Apr 2, 2006 | 11:33 AM
grlXer's Avatar
Default koni yellow inserts?
has anyone installed koni yellows. can you use oil in between shock cartridge and original shock housing to dissipate heat. or is heat not problematic. or is it necessary to drain old shock lube before cutting orig housing. i don't want to drill a hole into the shock housing if it isn't necessary>
Old Apr 2, 2006 | 12:41 PM
Battle Mike's Avatar
Default Re: koni yellow inserts? (grlXer)
you're going to have to drill a hole anyway when you do this. A bolt goes in at the bottom of the stock housing to thread into the insert to keep it still. Not too mention, the oil is under tons of pressure and will spray like hell everywhere. It's best to drain the oil first...be ready for when it sprays out.
here's a how to
http://www.k-series.com/tech_d..._KONI
dungsta
Suspension & Brakes
May 21, 2010 12:24 PM
JTTeG_X
Suspension & Brakes
Jun 3, 2006 05:26 AM
woody55
Suspension & Brakes
Dec 27, 2005 06:13 AM
rubens
Jul 18, 2003 09:11 PM
MidoriEK4
Feb 19, 2003 05:26 PM
