car idels up and down
Old Apr 2, 2006 | 11:33 AM
Milan0Gsr's Avatar
Default car idels up and down
I just bought a 96 ek, the only thing wrong with it is that the car idles up and down, with out me putting the foot on the gas, theres no check engine light , wanted to know if someone migt know whats wrong, and where can I find the part?
Old Apr 2, 2006 | 11:41 AM
ella94's Avatar
Need a bit more info.
Does it happen when the engine is first cranked?
Does the car have to be warmed up to operating temperatures before it idles funny?
Does it slowly go up and down or do the rpms slowly climb to 1200+~ then quickly fall back down to 700~ rpm, making it sound like a heartbeat or so?
You can always try tightening the screw on your trottle body, will help calm down the idle if its not a vacuum leak.
Old Apr 2, 2006 | 11:52 AM
Milan0Gsr's Avatar
minutes after you turn on the engine
and it keeps doing it it doesnt stop even after the car has been on for some time, it slowly goes up and down, i dont know the rpm readings because its a dx the cluster doesnt show me that, hope thats a little bit of a better description of my problem
Old Apr 2, 2006 | 11:54 AM
t o m's Avatar
Default Re: (Milan0Gsr)
IAC might have taken a dump
Old Apr 2, 2006 | 02:32 PM
johnecon2001's Avatar
Default Re: (integra type s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra type s &raquo;</TD></TR><TR><TD CLASS="quote">IAC might have taken a dump</TD></TR></TABLE>
More likely the TPS sensor just needs to be readjusted.
Old Apr 2, 2006 | 02:34 PM
SVOboy's Avatar
I have a similar problem, my IACV is stuck. Except my idle cycles very quickly.
Old Apr 2, 2006 | 02:36 PM
BALLIN H22 EK's Avatar
Default Re: (SVOboy)
prolly the TPS sensor
Old Apr 2, 2006 | 02:42 PM
PhatBoy5015's Avatar
Default Re: (BALLIN H22 EK)
Could be a vacuum leak. Check your intake manifold gasket.
Old Apr 2, 2006 | 03:33 PM
fmrprojects's Avatar
Default Re: (PhatBoy5015)
spray carb cleaner around the gaskets and see if there is a vacumm leak. if the car happens to idle coo at that point or die, then the leak is right there
Old Apr 2, 2006 | 03:46 PM
Bomanator's Avatar
Default Re: car idels up and down (Milan0Gsr)
Problem could be your fast idle air control. Locaated under the throttle body, held on with 3 small bolts. On the inside it looks like a black ring tighten that up and start the car aand see what happens. My car did the same thing it would jump like 500 rpms
Old Apr 2, 2006 | 03:59 PM
SVOboy's Avatar
A test to see if it is FITV or IACV:
Cover up one of the holes in the tb with your finger while the car is idling. I think the top hole is IACV and the bottom is FITV.
If the top hole coverage makes it idle normally, it's the IACV.
Same goes for the bottom.
This and the fact that when I unplug my IACV it idles normally has me convinced that my IACV is bad.
vynum
Jun 6, 2010 07:56 PM
meanshyguy
Oct 24, 2007 12:49 PM
psyonicdeath
Jul 1, 2005 07:25 PM
angelovargas
Jul 15, 2004 01:35 PM
0 0 0
30
Dec 18, 2002 06:25 PM
