Let's hear YOUR "how to" jdm ef8 front end guide...
I'll be doing my JDM EF8 bumper this week, I've read many how-tos, all different. Just trying to hear something new, maybe easier
Its actually pretty simple. Take off your old bumper and put on your new one. Is that easy enough for you?? LOL jking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurblowEF »</TD></TR><TR><TD CLASS="quote">Wont work dumbass, not even with major hacking , you knew this, you cant beat this</TD></TR></TABLE>
thats odd.
"unlike what most people tell you, the rad support is not the magic fix for this install. most rad supports come with an EF8 kit, but its not shaped any different than the USDM. the only difference is the hole for where the OEM intake went."
http://www.jdmuniverse.com/for...13089
thats odd.
It will NOT fit with the oem hood, the gaps will be outrageous and you cannot fix them
try it if you like
Ive seen 2 locals try with 2 different bumpers, both were disasters, one opted and completed his front end with jdm parts (including rad support) and the other modified the **** out of the bumper and it now semi lines up and has some nice sweet wrinkles
try it if you like
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurblowEF »</TD></TR><TR><TD CLASS="quote">It will NOT fit with the oem hood, the gaps will be outrageous and you cannot fix them
try it if you like
I have ef8 headlights, ef8 bumper, and VIS SIR (jdm hood)....
try it if you like
oh, you didnt ******* sya that lol
youre fine
just bolt on and go, you can have the old **** off and the new **** on in 3- hours or so, getting it lined up perfect will take time and expletive does moving those fenders suck *****, hope you have a helping hand, I didnt
youre fine
use a non dohc ef with si-r style front support . i:e; style sII
in the past ive used the jdm si-r support, and drilled the hood part of the mechanism so it will latch.
heres the factory usdm , same exact physical equivalent as far as hole for the latch. modified to work.
heres the part you need to have it bolt up factory style. no need to fuss with the hood mechanism .
I just recently installed my new front end and used the us rad support(i had the sir one too but like everyone says its the same)....i just used about 1in of washers on the 4 outside bolts to move the support forward to line up with the hood latch assembly(also leave the bottom bolt for the t part of the rad support unbolted)....it was a bitch to get it all aligned but it fits great with no gaps(i am running the jdm bumper support which helps alot)...sorry i only have some shittty pics but here ya go...good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 »</TD></TR><TR><TD CLASS="quote">Its actually pretty simple. Take off your old bumper and put on your new one. Is that easy enough for you?? LOL jking</TD></TR></TABLE>
thats pretty much it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy »</TD></TR><TR><TD CLASS="quote">get pics of the abs jdm front bumper for usdm front...how much will they run?</TD></TR></TABLE>
we are currently making a sir front bumper in abs that fits the us fronts with no mod needed
i hate companies that do this ****. its like selling knock offs of the mona-lisa. that **** is wack and i hope no one buys it and you go bankrupt, and get hit by a bus.
arthurcruz1
May 12, 2006 10:54 PM
wu tang
21
Nov 10, 2005 08:51 PM
