INSTALLING A JDM CLIMATE CONTROLL IN 92 EG CX
Old Apr 2, 2006 | 10:46 AM
J-SPEC-CALIFORNIA's Avatar
Default INSTALLING A JDM CLIMATE CONTROLL IN 92 EG CX
I AM CURRENTLY WORKING ON ANOTHER SWAP SO I DECIDED TO DO MY INTERIOR AT THE SAME TIME. I AM CHANGING THE GRAY CX DASH FOR A 95 BLACK SI AIR BAG DASHBOARD. THE JDM CLUSTER AND CLOCK ARE STRAIGHT FOWARD INSTALLS. ALTHOUGH THE JDM CLIMATE CONTROLL IS PHYSICALLY LONGER THAN THE USDM VERSION. THE JDM ONE IS ALL ELECTRONIC UNLIKE THE USDM THAT HAS A WIRE RUNNING TO THE COLD TO HEAT ADJUSTMENT ****. THE WIRES ARE NOT PLUG AND PLAY BECAUSE THEY ARE SLIGHTLY DIFFRENT.. .....
....I NEED HELP FROM ALL YOU SMART BROS. IF YOU HAVE A GOOD PAGE/LINK TO REFER ME TO I APPRECIATE IT.
Old Apr 2, 2006 | 12:12 PM
BlueIntegraBoy's Avatar
Default Re: INSTALLING A JDM CLIMATE CONTROLL IN 92 EG CX (J-SPEC-CALIFORNIA)
Just swap over the climate control faces and the bulbs onto the USDM climate control.
Old Apr 2, 2006 | 12:33 PM
nightrider's Avatar
Default Re: INSTALLING A JDM CLIMATE CONTROLL IN 92 EG CX (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Just swap over the climate control faces and the bulbs onto the USDM climate control.</TD></TR></TABLE>
unfortunately, with this method you won't have use of the auto feature of the jdm climate control unit.
Old Apr 2, 2006 | 12:47 PM
Default Re: INSTALLING A JDM CLIMATE CONTROLL IN 92 EG CX (nightrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider &raquo;</TD></TR><TR><TD CLASS="quote">
unfortunately, with this method you won't have use of the auto feature of the jdm climate control unit.</TD></TR></TABLE>
Well, unfortunately we live in the US where all the good OEM parts don't exist.
Old Apr 2, 2006 | 01:10 PM
cxSHOE's Avatar
i doubt he will want to switch over and splice the harness/sensors either? way too much trouble for it to work as it was meant. hence the face lift works for most.
plus he'll be wasting gas by using the autotemp feature anyway
Old Apr 2, 2006 | 09:15 PM
nightrider's Avatar
there's no point in the JDM cluster other than for looks. i mean, it's a better OEM piece because of the auto feature. without it, there is no functional benefit. just another JDM bandwagon item.
Old Apr 2, 2006 | 09:19 PM
Turbo_y8's Avatar
just paint your damn bulbs with spray paint. Fast. easy. cheap. and looks the same. I have people asking me all the time. I say spray paint
Old Apr 3, 2006 | 01:08 AM
drevinder's Avatar
Default Re: INSTALLING A JDM CLIMATE CONTROLL IN 92 EG CX (tuck'd98)
or just pop the front cover off jdm climate control and put it on ur's...along with the bulbs
Old Apr 3, 2006 | 10:02 PM
I FIGURED THE ONLY OPTION WOULD BE TO CHANGE THE FACE OR BULBS JUST WANTED TO MAKE SURE THER WASNT AN EFFICIENT METHOD IN ORDER TO GET THE COPLETE FUNCTIONING PART. I WOULDNT WANT TO PAINT THE BULBS BECAUSE WE DO **** AS LEGIT AS POSSIBLE YADADIMEEN
Old Apr 3, 2006 | 11:56 PM
sagron69's Avatar
Don't use caps, it's annoying.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-SPEC-CALIFORNIA &raquo;</TD></TR><TR><TD CLASS="quote">YADADIMEEN </TD></TR></TABLE>
And as a member of Northern California, I'd ask you not to use this word ever again... not just in this forum, but in real life... it's just, wrong.
Old Apr 4, 2006 | 07:27 AM
ITS SLANG... GO CORRECT AMERICA
Old Apr 4, 2006 | 07:55 AM
Turbo_y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-SPEC-CALIFORNIA &raquo;</TD></TR><TR><TD CLASS="quote">WE DO **** AS LEGIT AS POSSIBLE YADADIMEEN </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-SPEC-CALIFORNIA &raquo;</TD></TR><TR><TD CLASS="quote">ITS SLANG... GO CORRECT AMERICA</TD></TR></TABLE>
not speaking slang is not legit english....
Old Apr 4, 2006 | 04:33 PM
Default Re: INSTALLING A JDM CLIMATE CONTROLL IN 92 EG CX (sagron69)
WANTED!! NORTHEN / BAY AREA CALIFORNIA...
LOOKING FOR.
-ODB1 DOHC V-TECH 5 SPD. ENGINE HARNESS...
- HIT ME BACK AT bcmailcenter@yahoo.com.
Old Apr 4, 2006 | 08:55 PM
Turbo_y8's Avatar
and now this is a want to buy thread...
High Octane
Jul 30, 2009 12:24 PM
AmbiguousCivic
Nov 1, 2008 01:42 PM
steinbacheg6
Jun 30, 2008 10:42 AM
jdmeg6118
11
Apr 18, 2008 12:25 AM
YodajdmEK4
Dec 21, 2004 11:02 AM
