ecu question
Old Apr 2, 2006 | 09:48 AM
dosJDM's Avatar
Default ecu question
I have a b16b block b16a head and itr cams....which ecu should i be using? which would be the best to use? this is all on a 93 hatch
Old Apr 2, 2006 | 09:51 AM
Terrible One's Avatar
Default Re: ecu question (dosJDM)
obd1 ecu w/ pct basemap
Modified by Terrible One at 12:15 PM 4/2/2006
Old Apr 2, 2006 | 11:12 AM
FaceTuned's Avatar
any obd1 chipped ecu will run it fine or get a chipped p28,p72,p30 and start with a gsr base and tune it till you get a good a/f ratio and your idle is good all that stuff that people do when they tune cars you know
remember you got those domed *** pistons in there so you dont wonna run lean at all so dyno tune it with a wideband
good luck, and have fun
Old Apr 2, 2006 | 11:13 AM
FaceTuned's Avatar
Default Re: ecu question (Terrible One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Terrible One &raquo;</TD></TR><TR><TD CLASS="quote">obd1 ecu w/ pct basemap
Modified by Terrible One at 12:15 PM 4/2/2006</TD></TR></TABLE>
were do you find a pct basemap?
Old Apr 2, 2006 | 11:17 AM
Default Re: ecu question (jdmhatchness)
there was a page on pgmfi with bins for every honda motor possible, cant find it right now but its there
Old Apr 2, 2006 | 11:19 AM
FaceTuned's Avatar
no im sorry to bust your bubble but pct is obd2 and crome and uberdata havent been able to hack those codes yet the best thing to do is start with gsr base map and tune the **** out of it!
you were looking for this page http://www.pgmfi.org/twiki/bin...Codes
go done to the bottom save the pct file and try to open it with crome or uberdata it wont work. just try it out and you will see
Old Apr 2, 2006 | 11:33 AM
Default Re: (jdmhatchness)
well that sucks, i guess theres really no particular ecu that you can use that will make it run decent, even with a stock p30 you'll be running super lean up top. only choice is to run a chipped ecu and tune to perfection
Old Apr 2, 2006 | 11:39 AM
FaceTuned's Avatar
Old Apr 2, 2006 | 11:41 AM
FaceTuned's Avatar
start with the gsr base map and tune it from there and the motor will run fine just dont let the a/f ration lean or detonation will be your friend
Old Apr 2, 2006 | 12:37 PM
dosJDM's Avatar
thanks
JDmspoon22
18
Sep 4, 2007 09:09 AM
Mikes2000civicsi
Jan 30, 2007 11:42 AM
deadline
Nov 15, 2006 06:10 PM
adidasklip
May 3, 2006 08:51 AM
ShowtimesDC2
Sep 14, 2003 09:14 PM
