Loud ticking on acceleration. Fuel injectors?
Old Apr 2, 2006 | 08:15 AM
CRISIS's Avatar
Default Loud ticking on acceleration. Fuel injectors?
This will only happen when i step on the gas hard. Idle is fine. Stock b7. As soon as i let off it stops. Could this be the injectors? Also i have some 330's from a galant. Will those work with my stock ecu? Thanks in advance.
Old Apr 2, 2006 | 08:18 AM
SVOboy's Avatar
Dunno, but 330s will not work with the stock ecu.
Old Apr 2, 2006 | 08:41 AM
CRISIS's Avatar
Default Re: (SVOboy)
Well that sucks. Also, i think it's the injectors because the ticking is sparratic.
Old Apr 2, 2006 | 09:05 AM
SVOboy's Avatar
You can get some other 240s for *** cheap. I have an extra set lying around I think.
Old Apr 2, 2006 | 09:16 AM
CRISIS's Avatar
Well i was going to go turbo in like a month that's why i just wanted to throw the galant injectors in there. But i buddy of mind has some stock ones i could use. But thanks for the offer.
Old Apr 2, 2006 | 10:21 AM
SVOboy's Avatar
If you're going turbo might as well get the ecu chipped already in which case you can use the 330s.
Old Apr 2, 2006 | 11:42 AM
igo4bmx's Avatar
could it be your valves?
Old Apr 2, 2006 | 07:24 PM
CRISIS's Avatar
Default Re: (igo4bmx)
I've been thinking and hf i do seafoam will that clean out my injectors enough to stop the noise. Also i know i'm going to get a valve adjustment after i do sea foam. Thanks for the responses. So know one has had this problem?
Old Apr 2, 2006 | 07:30 PM
SVOboy's Avatar
To clean out your injectors well toss some acetone in the tank, just don't get any on the paint.
Old Apr 2, 2006 | 07:40 PM
CRISIS's Avatar
Will do. I can pick that up at a home depot right?
Old Apr 2, 2006 | 08:05 PM
strictly.business's Avatar
Banned
rod bearings/crank main bearings going out.
Old Apr 2, 2006 | 08:17 PM
SVOboy's Avatar
Just get 100% acetone nail polish at cvs, you only need a few ounces.
Old Apr 2, 2006 | 08:20 PM
CRISIS's Avatar
Default Re: (strictly.business)
rod bearings/main bearing? For real? I hope not because i don't have money for a new motor. DAMN!! Well if it blows i'll just get a h22 swap i guess. Lol! Just curious how much would it cost to fix that?
Old Apr 2, 2006 | 08:32 PM
SVOboy's Avatar
****, you can prolly get a b7 for like 50 bucks if not free.
Old Apr 2, 2006 | 08:51 PM
symph0ny's Avatar
Use a screwdriver to listen to your injectors... point on the injector handle on your ear. Move the throttle cable to see if they get worse at a higher rev.
Of course cleaning everything out is probably a good idea anyway, but you might want to change your fuel filter first (don't want to free up a bunch of crud).
Old Apr 2, 2006 | 09:07 PM
EJ8-y8's Avatar
what kind of mileage on the motor? every d-series i have ever had gets piston slap after about 180k
Old Apr 2, 2006 | 09:22 PM
Turbo_y8's Avatar
Default Re: (EJ8-y8)
yea, my buddy had a minime do this, thought the motor was trash, Bought a sirII swapped it same ****, replaced the injectors no more knock in the b. Sold the d for with tranny axles mounts for 100 and told the kid it might be the injector, and was
Old Apr 2, 2006 | 10:54 PM
paulzy's Avatar
a valve adjustment would be the cheapest to do first because it's free and it's routine maintenance
Old Apr 3, 2006 | 12:39 AM
PurEvl's Avatar
Default Re: (paul vang)
yes some injectors tick
dsm's tick fairly loud
Old Apr 3, 2006 | 03:12 PM
CRISIS's Avatar
Default Re: Loud ticking on acceleration. Fuel injectors? (CRISIS)
Bump it for an experience.
Old Apr 4, 2006 | 10:00 AM
CRISIS's Avatar
Autozone wants 85 bucks. Is this a normal price? For all 4 injectors and the motor has 127K on it.
Old Apr 4, 2006 | 11:35 AM
torqued's Avatar
Is it only when it is in gear and under load going down the road or does it do it in [P] or neutral too?If it's just when it's under load my guess is "Spark knock" from your timing being out of adjustment.Check your distributor cap and rotor and if they look good check your timing and make sure it is in or close to specification.Cap and Rotor Kit is $34.99 at AutoZone or the cap is $13.99 and the rotor is $9.99 and those are both normal stock items.Also check your spark plugs and make sure they are gapped correctly.I hope this helps.
Ryan
Old Apr 4, 2006 | 12:15 PM
civic_driver's Avatar
i was gonna say knock/pinging as well... check your timing belt/distributor timing
Old Apr 4, 2006 | 12:46 PM
civic93@8psi's Avatar
Default Re: (civic_driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver &raquo;</TD></TR><TR><TD CLASS="quote">i was gonna say knock/pinging as well... check your timing belt/distributor timing</TD></TR></TABLE>
+2
DETONATION mayb could be bad gas but check ignition timing
-mike
Old Apr 4, 2006 | 02:09 PM
CRISIS's Avatar
Default Re: (civic93@8psi)
Well i just checked my fuel injectors and they are good. The noise only comes in under load in drive (auto). It does not come out when i rev it in park. Now that it was mentioned detonation does sound like a possibillty. The noise started making itself known after i changed my distributor o ring. And recently it has been coming out real loud. I i have been running 87 octane since i got the car, i might have put 93 in a couple times. Checked my plugs and wires. They look good it seems like one of the spark plug boots doesn't want to snap on the end of the plug. Should i just do all my maintenance or say screw it and pick up a JDM d15b VTEC this weekend. Haha.
