jumper harness?
ok i am looking into a new engine for my 91 crx si. i found an engine that is in a 98 coupe it is the 1.6 non vtec, i beleive that is the d16y7, but you can correct me if i am wrong. i am not to good with wiring, so i am just making sure i am correct. all i would need to make this work is the obd1 to obd2 jumper harness right. everything else will just bolt up. let me know if i am wrong. thanks
im pretty sure your gonna have to do some more wiring, go to http://www.rywire.com they will tell you what you need
or hit up user droppedcrxsi (he's on ht)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by classciv »</TD></TR><TR><TD CLASS="quote">ok i am looking into a new engine for my 91 crx si. i found an engine that is in a 98 coupe it is the 1.6 non vtec, i beleive that is the d16y7, but you can correct me if i am wrong. i am not to good with wiring, so i am just making sure i am correct. all i would need to make this work is the obd1 to obd2 jumper harness right. everything else will just bolt up. let me know if i am wrong. thanks</TD></TR></TABLE>
No. If you want to run the OBD2 ecu, then you will need the pre-obd (OBD0) to OBD2a USDM conversion harness. Contact http://www.rywire.com and they can help you out with everything.
pingu
10
Feb 5, 2007 02:34 AM
madman13lm
10
May 5, 2003 05:14 AM
