b16 86mm setup, advice please!!
i have a b16a engine, im going n/a for a mild street build up. well i would be very happy to hit 205-210 WHP.
Modified by mikkey1 at 7:57 AM 11/25/2006
toda c's...make sure u get the 12.5 compression pistons.
your idle will be luck of the draw...imo
you will deff. need an aftermarket fpr and bigger injectors 310's hsould suffice
as long as motor broken in correctly and driven tuned...you should see the motor last.
DAgsr
Jul 23, 2006 05:58 PM
