HELP: i think i blew some fuse for my dome light
Old Apr 1, 2006 | 10:12 PM
cilvia's Avatar
Default HELP: i think i blew some fuse for my dome light
ok well i was creating something with paper clips so that i could have two led dome lights powered instead of one...but anyways...i forgot to turn the power off when doin this and i accidently let the negative and positive sides touch each other with the paper clips i was trying to form with...sparks came out and now the dome light doesnt work at all.......i also noticed that when my door is open, and i put my key in the ignition, i dont hear any alert sounds tellin me that the key is still in the ignition...did i blow my fuse?? i was looking at the fuse chart thingy under the drivers kick panel and i dont kno which fuse to check...how much would it cost to get one replaced at a honda dealership?? thanks
oh its for a 97 civic ex if you need to kno
Modified by cilvia at 11:53 PM 4/1/2006
Old Apr 1, 2006 | 10:17 PM
TheNasty0ne's Avatar
Default Re: HELP: i think i blew some fuse for my dome light (cilvia)
Just check all of them.
You get fuses at any auto store like auto zone, kragen etc...
Old Apr 1, 2006 | 10:41 PM
cxSHOE's Avatar
no need to check all of them.
look at one of the red 7.5 fuses on the lowest point on the fuse box...it will be number 3 spot on the fuse box from the left. and you should have a spare fuse on your fuse box aswell toward the far left.
Old Apr 1, 2006 | 10:54 PM
cilvia's Avatar
Default Re: HELP: i think i blew some fuse for my dome light (cxSHOE)
soo i dont need to buy any?? good to kno...oh and whats the proper way to check the fuses and remove them?? do i have to remove the negative from the battery or what?? thanks
Old Apr 1, 2006 | 10:55 PM
cxSHOE's Avatar
never mind what i posted that was for the eg civic... you have a 96+
open your hood, pop off your engine bay fuse cover, (next to the battery)
you are going to remove the #43 fuse which is a 7.5 fuse
Old Apr 1, 2006 | 10:56 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cilvia &raquo;</TD></TR><TR><TD CLASS="quote">soo i dont need to buy any?? good to kno...oh and whats the proper way to check the fuses and remove them?? do i have to remove the negative from the battery or what?? thanks</TD></TR></TABLE>
you should have a little puller under the dash fuse box, or you can just pull it with your hand.. no need to remove any batt. cables..
Old Apr 1, 2006 | 11:43 PM
cilvia's Avatar
heres my fuse chart that i just uploaded if this would help...
Old Apr 2, 2006 | 12:24 AM
Ragecloak's Avatar
see that little silver piece in the clear part in the middle that's just "floating" there not connecting to anything? That's cause it used to be connected to the other piece that it's kinda pointing at, but it's popped...that's what a blown fuse looks like...a break anywhere on that link
Old Apr 2, 2006 | 03:31 AM
7808's Avatar
Default Re: HELP: i think i blew some fuse for my dome light (Ragecloak)
wow you suck. help did i blow my fuse?
fast way = get a multimeter set it to continuity check and poke the probes in the tops of each fuse. it will beep if there good.
Old Apr 2, 2006 | 08:50 AM
cilvia's Avatar
Default Re: HELP: i think i blew some fuse for my dome light (7808)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">wow you suck. help did i blow my fuse?
fast way = get a multimeter set it to continuity check and poke the probes in the tops of each fuse. it will beep if there good. </TD></TR></TABLE>
can i use a electric tester to touch the tops of each fuse??
Old Apr 2, 2006 | 09:36 AM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">never mind what i posted that was for the eg civic... you have a 96+
you are going to remove the #43 fuse which is a 7.5 fuse </TD></TR></TABLE>
follow my instructions here.. end of story. heres a picture of your engine fuse box.. along with where #43 fuse is located..
lets be done with this already
Old Apr 2, 2006 | 11:28 PM
cilvia's Avatar
wheres the fuse box at in the engine bay??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cilvia &raquo;</TD></TR><TR><TD CLASS="quote">wheres the fuse box at in the engine bay??</TD></TR></TABLE>
Next to the battery.
Old Apr 3, 2006 | 09:33 AM
cxSHOE's Avatar
i give up did you even read what i wrote, i even have it in parenthesis???
i am out...
good luck
KelvinR
Oct 31, 2011 11:17 AM
1992gsrblack
May 3, 2011 12:32 PM
Shannon626
May 29, 2008 11:03 PM
62maxx
Oct 25, 2006 03:45 PM
