b16a dies out, sputters and cuts.
Old Apr 1, 2006 | 09:40 PM
jdmazm's Avatar
Default b16a dies out, sputters and cuts.
Ok guys, I'm getting fed up with this.
Background: I installed this motor about 6 months ago, ran fine no problems, never had a CEL until an o2 sensor went out. Well, fixed that. Ran fine for a week then another problem.
Problem: Every now and then the car would sputter and cut off while I would be driving. The car wouldn't die, the lights stay on in the dash. If I hit the accelerator the car would bog and the revs would keep dropping. Then I had to turn off the car and start it back up and it would drive fine again for 5 minutes and it would cut off again. Motor still hit VTEC and ran hard when it would work. It has been getting worse and worse and now won't even stay on for 10 seconds. The car would crank and turn over but cut off again.
I thought it was a fuel problem so I changed my fuel injectors, fuel pressure regulator, and resistor box for the injectors. Then the spark plugs and wires, got a new dizzy cap and rotor. Still same problem.
I need to get my car running so I can get to college and work its kinda pissing me off.
Any ideas guys?? Thanks in advance.
Old Apr 2, 2006 | 04:40 AM
yellowrexsi's Avatar
Default Re: b16a dies out, sputters and cuts. (jdmazm)
Could be the ignitor on the distributor or the main relay. you are going to have to find out if its a spark or fuel problem.
Old Apr 2, 2006 | 04:50 AM
j3z3z's Avatar
im have this same problem at the moment really pissing me off. i think i going to go for a swap to a JDM B18C7r cause for the last 4 months all i have copped is **** from my b16a
Old Apr 2, 2006 | 08:02 AM
EF_ST@TUS's Avatar
Default Re: (j3z3z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j3z3z &raquo;</TD></TR><TR><TD CLASS="quote">im have this same problem at the moment really pissing me off. i think i going to go for a swap to a JDM B18C7r cause for the last 4 months all i have copped is **** from my b16a</TD></TR></TABLE>
Does it pick up at like 2500 rpms? mine boggs if I floor it, then picks up power at 2500. but if I just give it gas slowly it revs fine.....I cant figure it out. I think timing maybe, but I'm goin through it all. have new dist.
Old Apr 2, 2006 | 12:51 PM
jdmazm's Avatar
Default Re: (Lost_in_a_world_so_cold)
bump for more answers
Old Apr 2, 2006 | 04:54 PM
EF_ST@TUS's Avatar
bump for answers
Old Apr 2, 2006 | 06:18 PM
jdmazm's Avatar
would a fuel pressure regulator do this.
Old Apr 2, 2006 | 08:21 PM
jdmazm's Avatar
Default Re: (jdmazm)
ttt
Old Apr 3, 2006 | 07:34 PM
jdmazm's Avatar
top
need answers.
Old Apr 5, 2006 | 07:22 PM
jdmazm's Avatar
one more time
Old Apr 5, 2006 | 08:21 PM
crxnj's Avatar
Sounds like an o2 sensor problem to me..maybe you have the wires switched around? Or could be the ignitor..
Old Apr 6, 2006 | 06:27 AM
jdmazm's Avatar
Default Re: (Mr.speaker)
o2 sensors would make the car cut out? i would think it would run really bad but not cut out. I'll check it out.
I changed the ignitor, but i'll double check
Old Apr 6, 2006 | 11:49 AM
jdmazm's Avatar
changed the main relay. car stays on longer. Now the rpms don't work, when i hook it up to a battery it will turn over no problems at all car runs, good idle everything works.
when i disconnect the jumper the car wants to die the lights dim out.
Old Apr 6, 2006 | 04:31 PM
hondaguyexsi's Avatar
hey man just basically look at everything.. it could be anything... check everything on your fuel sysem and ignition system.. that will be the only way to find the proble or get someone with a scanner of some sort to look at the o2 voltage when ur driving...
Old Apr 7, 2006 | 08:15 PM
jdmazm's Avatar
Default Re: (hondaguyexsi)
problem fixed.
Old Apr 8, 2006 | 02:30 AM
hb_guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmazm &raquo;</TD></TR><TR><TD CLASS="quote">problem fixed.</TD></TR></TABLE>
so what was it?
Old Apr 9, 2006 | 07:13 PM
jdmazm's Avatar
Default Re: (hb_guy)
main relay, and alternator. Also changed my ignition coil in the dizzy.
a world of difference.
Ryhaz
16
Mar 16, 2014 07:13 AM
mandajane92
Honda S2000
Jul 22, 2013 09:37 PM
TiMiD703
May 15, 2007 08:59 AM
SoCal ITR
May 6, 2004 10:27 PM
