Front sway bar sizes???For sols? Civics? Tegs?
Searches usually work......
I know the civics though.
The ones that came with front bars had 22mm except the 99-00 SI which had 26mm.
Teg I believe is 22mm in front as well except the Type R which has a 25mm.
i DID search in fact
and guess what
nothing
hence my post
I want to know what fron the del sol vtec came with!
or can I put a tegs 26mm front on there?
and guess what
nothing
hence my post
will the usdm 99-00 SI bar fit an eg chassis del sol??
or will only the DC (teg) bars fit?
how big a front did the del sol vtec have again???
GenIII Integra's
JDM ITR 25mm(F) 23mm(R)
USDM ITR 24mm(F) 22mm(R)
USDM GS-R 24mm(F) 14mm(R)
RS/LS/GS/SE 22mm(F) 13mm(R)
GenVI Civic Si 26mm(F) 13mm(R) - different [rear] endlinks (but still compatible across the board); also - different mounting brackets (I know the GenVI Civic's Neuspeed rear swaybar brackets won't fit on GenIII Integra's and thus also GenV Civic's)
The Civic Si front swaybar would probably be OK in a del Sol, but I can't say for sure. I've never tested the possibility that a Civic Si Front swaybar could fit on an Integra either, but the endlinks are the same, but I'm not sure about the bends in the bar. They might make contact with the subframe or something else...GenVI Civic's and GenIII Integra's have different front subframes, as well as a front subframe bar.
[Modified by IN VTEC, 9:29 AM 4/5/2002]
phantom_sol
Apr 24, 2003 01:27 PM
phantom_sol
Apr 6, 2003 05:11 PM
BLK JDM
Jan 23, 2003 09:45 AM
