5th Generation Coolant Capacity
Old Apr 1, 2006 | 04:39 PM
fiftyOne's Avatar
Default 5th Generation Coolant Capacity
Can anyone please tell me what the coolant capacity is for a fifth generation 2.2VTEC with an automatic transmission is?
A guidebook I have states that it is only 3.7L, but that sounds too small. Can anybody clarify this please?
Old Apr 1, 2006 | 10:10 PM
Honda-Master's Avatar
Default Re: 5th Generation Coolant Capacity (fiftyOne)
just loosen the bleeder screw and add coolant till it comes out ........why would you want to know the capacity??
Old Apr 2, 2006 | 11:32 PM
fiftyOne's Avatar
Default Re: 5th Generation Coolant Capacity (Honda-Master)
I am doing a radiator flush and will have to replace the coolant. I need a minimum mix of 50:50 ratio of anti-freeze to water. I would only know what amount of anti-freeze to purchase if I knew the capacity of the cooling system.
The book I have does give me a figure of 3.7L, but previous cars I have owned had required closer to 6.0. I was hoping someone would be able confirm whether the above figure was correct.
Old Apr 3, 2006 | 06:38 AM
accord-pro's Avatar
auto tranny 5.7 qts
manual tranny 5.16 qts
Old Apr 3, 2006 | 06:56 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: 5th Generation Coolant Capacity (accord-pro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Helm manual &raquo;</TD></TR><TR><TD CLASS="quote">Engine Coolant Refill Capacity: Including reservoir
(0.6 l (0.6 US qt, 0.5 lmp qt)).
M/T: 5.4 l (5.7 US qt, 4.8 lmp qt)
A/T: 5.3 l (5.6 US qt, 4.7 lmp qt)</TD></TR></TABLE>
When I refilled my 95 EX (F22B1 w/ manual tranny) I bought 1 gallon of un-mixed coolant from Honda, bought 1 gallon of distilled water and mixed the two to a 50/50 mixture. So I started out with 2 gallons and I still had plenty left over when I was done filling the system.
So just pick up 1 gallon of un-mixed coolant and mix it or pick up 2 gallons of pre-mixed coolant and you'll be fine.
Old Apr 3, 2006 | 10:10 PM
fiftyOne's Avatar
Default Re: 5th Generation Coolant Capacity (TouringAccord)
Awesome. Thanks for your help.
Old Apr 4, 2006 | 03:05 AM
H-T Order of Merit
yep, np
Old Oct 17, 2012 | 02:56 PM
Lillogan's Avatar
Remember to fill the resistor bottle
Lillogan's Avatar
Reservoir bottle to full line
PphamEK
Mar 16, 2009 12:43 PM
vroomboom
Honda Civic (2001 - 2005)
May 22, 2008 04:44 AM
invisible
Honda Civic (2006 - 2015)
Mar 24, 2008 08:51 AM
laughinxxx
Jun 27, 2002 11:33 PM
JL 74
Mar 8, 2002 08:46 AM
