jdm vs usdm
Old Apr 1, 2006 | 04:03 PM
DAGAME's Avatar
Default jdm vs usdm
i have a 96 accord with jdm h22a and i have to replace crank bolt, crank pulley, and crank key will the usdm prelude parts work for the jdm motor, if not where could i find these parts for the jdm motor?
Old Apr 1, 2006 | 04:20 PM
jfish's Avatar
Default Re: jdm vs usdm (DAGAME)
All the same
Old Apr 1, 2006 | 04:24 PM
Stew Pidasso's Avatar
They should bolt up fine. Just curious as to why you need to replace them...
Old Apr 1, 2006 | 04:26 PM
DAGAME's Avatar
sorry forgot to mention i purchased the usdm 98 prelude crank bolt and pulley the bolt is bigger in diameter and longer then the broken bolt i pulled off the crankshaft.
Old Apr 2, 2006 | 06:24 AM
h22 civic's Avatar
Default Re: (DAGAME)
they are different the 94 jdm bolts are bigger the usdm 95 crank bolt is smaller im not sure aboult the woodruff key though
UK_Luder
Apr 6, 2009 03:10 PM
AznPimpS
May 5, 2006 02:40 PM
TheAccordGuy
Apr 21, 2006 10:36 AM
Incubus05
Aug 2, 2005 01:29 PM
