Rear disk conversion 97 accord
Old Apr 1, 2006 | 01:11 PM
teamrevolution's Avatar
Default Rear disk conversion 97 accord
Thank you for your time. I have a 97 accord with a h22 swap in it and want to Chang out my rear drum brakes. I have a 93 is in the back of the shop. Can I swap the rooters out or do I need to pull them of another accord thanks you for the help.
Old Apr 2, 2006 | 02:12 PM
gianinline's Avatar
Default Re: Rear disk conversion 97 accord (teamrevolution)
https://honda-tech.com/zerothread?id=534520
Here's a link that could help you!
Old Apr 7, 2006 | 05:05 PM
Default Re: Rear disk conversion 97 accord (gianinline)
Thank you but that did not help me much. I don't know all the generations of accord and civics. And a lot of that was slang to me. I am trying to learn more about Hondas but I am a little lost when it comes to breaks has any one out there done this swap that can give me a strait answer.
Old Apr 7, 2006 | 07:50 PM
YeuEmMaiMai's Avatar
first things first. If you have 15" rims or larger and have not converted the fronts to the V6 brakes, I'd do that first as it:
Will incrasse your stopping power (stopping distance is shorter)
removes the pressed on rotors
converting the rears won't do jack to make the car stop quicker and are for cosmetic reasons only...........
Old Apr 8, 2006 | 10:31 AM
iam7head's Avatar
Default Re: Rear disk conversion 97 accord (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">first things first. If you have 15" rims or larger and have not converted the fronts to the V6 brakes, I'd do that first as it:
converting the rears won't do jack to make the car stop quicker and are for cosmetic reasons only...........</TD></TR></TABLE>
it would help a little but do realize that LX/SE/DX's drum does not come with ABS so it's not going to use the disk to the fullest
unless you got all the junk really cheap, it's a waste of money if you looking for performance wise gain
Old Apr 8, 2006 | 11:43 AM
SuShiBoiiii's Avatar
http://www.cb7tuner.com/vbb/showthread.php?t=16241 hope it helps a lil
Old Apr 8, 2006 | 05:07 PM
Thanks everyone that helps a lot. The car is used for auto cross so every little bit helps. The problem I find is that after a few corners the drums start to heat up and become just about useless. Thanks foot the help any other advice would be helpful I am sure. Thanks again.
warrenf11
Feb 4, 2014 05:36 PM
91EfRaCer
Mar 17, 2010 04:54 PM
JDM Panda
Oct 13, 2009 10:56 AM
cooldudeness
Oct 4, 2009 04:52 PM
