h22a hatch wont start(obd1 h22a ek)
okay i just put swapped in a new h22a motor in my hatch, it started up just fine but i couldnt rev it up without it dying, it was trowing a code 16 fuel injectors, one of my plugs wasnt getting any power, so i unpluged everything, trying to find if the wire was ripped anyware all the wires were good then i saw that a wire was coming loose from the resistor plug so i clicked it back in and tapped the harness back up, and thought i had pluged everything back up so i tried starting it nothing, so i found out i forgot to hook up the starter, then i tried it again it turns over but nothing, i dont hear the fuel pump coming on and theres no spark, it trows a soild cel. im lost, i really need somoe HELP!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SixguN »</TD></TR><TR><TD CLASS="quote">Are you sure your resistor is hooked up correctly? I just had a problem very similar the other day. Solid code, won't start etc.</TD></TR></TABLE>
Did you finally get it worked out. yeah definately check your wiring, did you solder your resistor box in, it sounded like you just taped it together?
